Question: 540 direct drive motor for Bronco's Type XXIII
    • 3613
    Acquired a couple of stock Tamiya RS540 silver can motors. Plan to use it in my Type xxiii. Will this motor be sufficient on direct drive or would I need a gear system?
    • 2548
    Too big, and too high revving.
    For direct drive you want a motor that does no more than about 4-5000RPM unloaded. A better choice would be a 385 geared down 3:1.
      • 651
      Go on the engel site, they have some nice low speed 540 cans and ship o seas for reasonable price
        • 3613
        Shoot!
        Might as well finish the Kilo first.
          • 13831
          Shoot!
          Test, test, test (tapping sounds)... test, test (feed-back squeal), is this thing on???....
          Did Romel just say something about his long-suffering KILO project?
            • 3613
            David looks like you have a bad case of Presbycusis
            • crazygary
              • Sep 2012
              • 610
              Ey??? What's that ye say, sonny????
              CG
                • 2548
                Don't think he believes me, noticed the same question has been freshly asked on rcgroups.
                Okay to illustrate my point, don't know the exact size of the Type XXIII prop, but estimate somewhere in the region of 1 3/4" or about 45mm.
                The silver cans from the Tamiya kits spin about 15-16k RPM unloaded. They're a three pole motor with a 27 turn wind. As such they're designed to be geared down to provide the high torque required to accelerate a model car adequately.
                With a scale prop, lets say pitched at a 1:1 diameter to pitch ratio, we can calculate with 25% slip
                15000x1.75/1408= 19 mph
                Lets say the motor loads down by 25% and is working at, or close to maximum efficiency.
                11250x1.75/1408= 14 mph
                As you can see this is far too fast, and in fact it is academic, as the boat just won't handle that power.
                Now if you were to gear the motor down 3 or 4:1 then you'll have a working set-up, but it will be rather inefficient, as those motors are quite thirsty even when run unloaded.
                  • 3613
                  What ever made you think i don't believe you?
                  Thanks for info.
                  Thinking of getting one of those 12 volts from the auto salvage yard. Would those work?
                    • 2548
                    I don't know. What you need is a motor that can do about 4-5000 RPM unloaded. Any more than that and you will have a speed boat on your hands, and it's likely to be inefficient as the motor will be overloaded on a scale prop.
                    But, get your Kilo finished and going first.
                      • 3613
                      Guess that also rules out the only other available motor I was offered, a Permax 400, it has no load rpm of 16,800. Will look for a 380.
                        • 13831
                        No!
                        Drop all this secondary, distracting **** and pull that KILO down off the shelf, dust it off.... AND FINISH IT!
                        Crawl, stumble, walk, run, and only after you've done all that, SPRINT!
                        FOCUS!!!!!
                          • 3613
                          Found a local shop selling electronics/ robotic equipment. This is what they got https://www.google.com.ph/url?sa=t&s...FmS81xlJPpnlWQ
                            • 3613
                            Like i said, will finish the Kilo first and figure the Type 23 drive motor dilemna later...
