Some Day-To-Day Work in the Cave
    • 13906
    Business is judged to be good or bad around here by how many times I have to make new tooling of old product. Time has come around to make fresh rubber molds from which to produce 3.5 SD bulkheads, Moebius SEAVIEW metal parts and pump-jets, and the Trumpeter SEAWOLF pump-jet.
    As one never stops learning to better practice their Craft, I've incorporated improvements into the tool geometry that will greatly reduce the clean-up labor the old tooling imparted on production parts.
ID:	102678Click image for larger version
ID:	102679Click image for larger version
ID:	102680Click image for larger version
ID:	102681Click image for larger version
ID:	102682Click image for larger version
ID:	102683Click image for larger version
ID:	102684Click image for larger version
ID:	102685Click image for larger version
  • Anuci
    Banned
    • 165
    Ellie is becoming more beautiful with each passing day, Dave. I hate you! LOL
    • SSBN659
      • 418
      David, help me out here please. What is the function of the 3 vertical brass tubes in pix 2, 4, 5, 6, and 7? Are they for pouring and venting?
      SSBN659
        • 13906
        SSBN659
        Sorry about the delay, forgot my password. Duh!
        The two outboard holes in the disc type tool pass the machines hold-down studs. The central hole is the 'sprue hole' through which molten metal is poured as the disc spins.
ID:	83024Click image for larger version
ID:	83025Click image for larger version
ID:	83026Click image for larger version
ID:	83027Click image for larger version
ID:	83028Click image for larger version
ID:	83029Click image for larger version
ID:	83030Click image for larger version
          • 13906
          Damned right, Al! Mine! ... all mine!!!!
          • Anuci
            Banned
            • 165
            Be that way, Dave. : )
            Seriously, It's nice to see Ellie doing better, and Rose helping her Pop Pop catch up with the work load.
            Now, if you send me your address, I'll get some replacement tee shirts right out to ya in time for your next photo shoot. LOL
            • SSBN659
              • 418
              OK, got it now. Thanks.
              SSBN659
                • 13906
                I did look a bit ragged there, didn't I?!
                  • 3643
                  Hopefully you don't come into the workshop one day not wearing any pants!
                    • 13906
                    Too late ...
                      • 13906
                      Finished the metal casting tool and also put together a jig so I can easily drill and tap the parts.
ID:	83040Click image for larger version
ID:	83041Click image for larger version
ID:	83042Click image for larger version
ID:	83043Click image for larger version
ID:	83044Click image for larger version
ID:	83045Click image for larger version
ID:	83046Click image for larger version
ID:	83047Click image for larger version
                        • 13906
ID:	83070Click image for larger version
ID:	83071Click image for larger version
ID:	83072Click image for larger version
ID:	83073Click image for larger version
ID:	83074Click image for larger version
ID:	83075Click image for larger version
ID:	83076Click image for larger version
ID:	83077Click image for larger version
                          • 13906
                          Today I play Pattern Maker. Stuff for a 1/72 THRESHER I'm working up for my pal, Fred.
ID:	83208Click image for larger version
ID:	83209Click image for larger version
ID:	83210Click image for larger version
ID:	83211Click image for larger version
ID:	83212Click image for larger version
ID:	83213Click image for larger version
ID:	83214Click image for larger version
ID:	83215Click image for larger version
ID:	83216Click image for larger version
ID:	83217Click image for larger version
ID:	83218Click image for larger version
ID:	83219Click image for larger version
ID:	83220Click image for larger version
ID:	83221Click image for larger version
ID:	83222Click image for larger version
ID:	83223Click image for larger version
ID:	83224Click image for larger version
ID:	83225Click image for larger version
                            • 13906
ID:	83236Click image for larger version
ID:	83237Click image for larger version
ID:	83238Click image for larger version
ID:	83239Click image for larger version
ID:	83240Click image for larger version
ID:	83241Click image for larger version
ID:	83242Click image for larger version
ID:	83243Click image for larger version
ID:	83244Click image for larger version
                              • 13906
ID:	83255Click image for larger version
ID:	83256Click image for larger version
ID:	83257Click image for larger version
ID:	83258Click image for larger version
ID:	83259Click image for larger version
ID:	83260Click image for larger version
ID:	83261Click image for larger version
ID:	83262Click image for larger version
ID:	83263Click image for larger version
ID:	83264Click image for larger version
ID:	83265Click image for larger version
ID:	83266Click image for larger version
ID:	83267Click image for larger version
ID:	83268Click image for larger version
ID:	83269Click image for larger version
