dive plane retract
  • fhouldson
    • Feb 2013
    • 45
    dive plane retract
    need picture of retract likage or info on the best way to set it up on a revell gato
    • 3746
    Welcome to this forum.
    Take a look here and see if this helps:
    • fhouldson
      • Feb 2013
      • 45
      it helped. would like pictures of the aft linkage setup on bow plane retracts
        • 13971
        Hey! How about buying the GATO DVD's???!!!!.....
          • 3746
          Duh! (smacking forehead), that is something i should have mentioned! The DVDs are worth getting. There are tips in there that alone are worth purchasing the DVD alone. If you read my Gato build I think I mention it enough times, buy the DVDs.
          • fhouldson
            • Feb 2013
            • 45
            I have the dvd's. The fitting kit for the retract is not the same as in the dvd's.
              • 3746
              If you follow my Gato build with the DVDs, it should cover the areas you are unsure about.
              • fhouldson
                • Feb 2013
                • 45
                Followed your build on the gato. It help me a whole lot and answered a lot of questions.
                thank you
                  • 3746
                  You are welcome. Put your build here and share with all of us!
                  • fhouldson
                    • Feb 2013
                    • 45
                    Will get some build pic soon and post them. I have a battery eliminator circuit. I'm a little dence on this. No info on this. Not sure where it goes. need help.
                    • fhouldson
                      • Feb 2013
                      • 45
                      any idea where the battery eliminator circuit hooks up to
                        • 3746
                        Yes, it taps off of your main battery power. Then the regulated voltage is used for the other devices (like RX)
                        If your ESC has a BEC built in you will need to disconnect the red wire. (see post)
