Bubble-free resin casting
    I remember reading an article in a modeling magazine that if you want a bubble-free resin casting you should de-gas the resin mixture in a vacuum pot prior to pouring to minimize bubbles.
    Does anybody have experience with this technique? How does the finished casting compare with those using a pressure pot?
    You would need a resin with a LONG set time. That is why usually you will see rubber vacuumed and resin in a pressure pot.
