When will the Skipjack manual be ready?
  • Tugfan
    • Nov 2010
    • 178
    Anyone know? I would like to print and bind it.
    When the last model is sold!
    • Tugfan
      • Nov 2010
      • 178
      :pop Get busy.
        • 14008
        Part-1 is already available as a down-load. Don't tell me you're ready for part-2!!!!!!!!!!!!!!!!!!!!!!!!!!!
        • Tugfan
          • Nov 2010
          • 178
          Where is part 1 at?
            • 3769
            Tugfan,
            Here is the link:
            Where are the photos from your build? I really want to see what you have going on!
            Tom
              • 14008
              Yeah! ... what he said! On both counts!
              • Tugfan
                • Nov 2010
                • 178
                Tugfan,
                Here is the link:
                Tom
                I will take some photo's tonight.
                  • 14008
                  Get to it! Chop, chop! Now!
                  (that felt good)
                    • 3769
                    Excellent, look forward to them. It is really cool to see what people are working on and the subtle differences in building style. I learn from all of them.
                    • Tugfan
                      • Nov 2010
                      • 178
ID:	74729Got the hull glued together, the Z cut and flood holes cut out and the SD mounts glued.Click image for larger version
                        • 3769
                        Coming along nicely! What are you going to do next?
                        • Tugfan
                          • Nov 2010
                          • 178
                          Put in the SD shock stop, rudder and dive planes, shafts, couplings, etc. I noticed that Dave skipped the SD tie down part on his instructions. You can tell how it goes in so that won't be a problem.
                            • 14008
                            [ATTACH=CONFIG]17190[/ATTACH]Got the hull glued together, the Z cut and flood holes cut out and the SD mounts glued.[ATTACH=CONFIG]17191[/ATTACH]
                            Bout time!
                            • Tugfan
                              • Nov 2010
                              • 178
                              I'm kinda confused by this paragraph: Remove the shock absorber and grind away a 1/2" wide, 3/8" deep channel down
                              between the two halves of the Sub-driver forward foundations. This channel permits disassembly of the shock-absorber components, should that every (sp) be necessary. Why is the channel necessary? The foundation is already separated at the bottom.
