Adjusting the subdriver ballast vent/blow mechanism
    • 3638
    Mike Caswell used to have a YT video showing you discussing how to make step by step adjustments to the vent/ blow mechanism in the 2-2.5 inch subdrivers. Unfortunately the video is gone. Hope you could make a new one or post a guide manual here.
    • 1628
    I don’t know if it will help you, but I found this.
    Technology - The knowledge and the equipment you'll need to construct and operate your radio controlled model submarine. Table of contents: - Submerging - absolute basics. - Dive planes. - Model types - static divers and dynamic divers - Model submarine ballast systems - The volume of your ballast tank - Sealing the moving parts
      • 13888
      Apparently the Caswell stuff is no longer available. Out of my hands.
        • 3638
        Thanks Das but it was specific to David's 2-3" subdrivers. There are 3 adjustment points were you could alter or fine tune vent and blow (how much propel to released) i
          • 3724
          David, that might be a good video to do for your YouTube channel.
            • 3638
            Would be quite helpful as there are still a lot of subdriver owners out there.
              • 13888
                • 3638
                I remember in your old video that younoted that shouldn't try all adjustment point simultaneously. Wheel collars first, the schraeder blow valve next. Reserving the flap valve screw the last.
                  • 13888
                  Correct. Thanks for the augmentation. My video was far from complete and poorly produced. Not my best effort at that sort of thing.
