Thoughts on Maximus-Modelbau Bronco XXiii WTC
  • Timothy L
    • Sep 2024
    • 246
    I haven’t been able to locate on the forum any Bronco builds using the Maximus-Modelbau Bronco WTC and conversion kit. If you know a build thread or have experience with the MM conversion kit, I would love to hear your thoughts. Thank you in advance.
    Tim
    • 2639
    If you cannot find one for the XXIII, then maybe look for build threads on other models in their range as they tend to follow a common theme. They make extensive use of 3d printed parts using filament and resin printers
      Not much info about this particular wtc in forums.
      Is David Marquez here or maybe someone here who knowns him can direct you to him.
      He used one of Maximus' WTC in a 32nd Parallel Type XXIII. These are from the Subcommittee FB page last December. Click image for larger version
ID:	193279 Click image for larger version
      • Timothy L
        • Sep 2024
        • 246
        Thank you. I’ve written to Maximus-modelbau to learn a little more about the product and will report back if I hear some useful information .
        Tim
