Subtech ST-10 Submarine Throttle Instruction Sheet; Anyone got one to share?
  • wlambing
    • Nov 2020
    • 399
    I obtained a couple of NOS units of the above throttle, but not in their original packaging, so they are without set-up instructions. I thought they might be good to use in something since Mtroniks has had issues lately. Anyone got the instructions they could share with us?
    TIA,
    Bill
  • SubSteve
    • Apr 2022
    • 145
    ST-10 ESC Instructions.pdf
    See attached.
      • 13998
      Originally posted by SubSteve
      [ATTACH]n191064[/ATTACH]
      See attached.
      Not recommended. It uses a mechanical polarity switching relay that often sticks or works intermittently. Get an ESC with a proper H-bridge circuit. Or, be plaques by a problem mechanical speed-controller.
      • wlambing
        • Nov 2020
        • 399
        Ah! Thank you, guys! I will keep these things in reserve for some not so important project. Meantime, work continues with well-established equipage.
