3.5/2 Sub-driver (3.5", twin-props)
  • toppack
    • Nov 2008
    • 1124
    I was looking for pictures and discription of the 3.5/2 SD Kit, for the T-class, on website, but could not find them. Did 'I miss it' or 'Is it Missing'???
    Rick L.
  • toppack
    • Nov 2008
    • 1124
    *I assume the 3.5/2 SD has a separate battery tube, correct? (connected externally)
    What's it's Length, I assume it's 3.5" diameter?
    I'm wondering how large a battery-pack will fit in it?
    *Does it have holes in aft bulkhead for 4 servos and snort-pump tubes?
    I'm trying to determine how many functions I can install, with 7 channel receiver?
    (along with 2 Torpedos, per 1 receiver channel)
    Rick L.
      • 13627
      The battery WTC is designed for it and will hold two large capacity Lithium-polymer packs. Look at the Caswell site.
      The motor bulkhead comes ported for the LPB induction and discharge hoses and has four installed and tested 1/16" pushrod seals.
      • toppack
        • Nov 2008
        • 1124
        I saw a 3" WTC.
        Is that what you have included with the 3.5" SD kit?
        I don't use Lithium-polymer batteries (Bombs), so need to know other options there.
        I would prefer to put a 12.volt Gel-cel in it, if it will fit.
        I still need to know it's length also.
        I still can't find a discription of what is included with the 3.5/2 SD, on the website ???
        Are you guys trying to keep all this Information 'Secret', or what? :D
        If so, it sure doesn't help in purchase selections. ;)
        Rick L.
          • 13627
          I saw a 3" WTC.
          I don't use Lithium-polymer batteries, so need to know other options there.
          I would prefer to put a Gel-cel in it, if it will fit.
          Hey!...
          ... I'm dancing as fast as I can!
          As designed, the WTC-3.5's (now called SubDriver's) were intended to be powered off an external gel-cell battery, so you're good to go in that department. And, no, the WTC-3 battery compartment is not part of the 3.5" package. You buy that little sucker separately.
          I'm busy developing a 1.25" diameter SubDriver over the holiday ... that's right: 1.25"!!!!! Going good so far and will be adaptable to just about every plastic model kit out there with a length between 15-25 inches. Film at eleven!
          • toppack
            • Nov 2008
            • 1124
            No Hurry....We got plenty of time. :)
            Okay,
            So, No battery compartment included or needed (if using a sealed Gel-cel).
            Just a little RTV on the battery terminals, correct?
            But that means that the On/off switch will need to be mounted on the aft bulkhead with everything else? It's too thick for a switch to mount there, Isn't it?
            So, I guess the switch would have to be mounted in the wire and potted up in RTV? :confused:
            Or do you just seal up one battery-terminal and use the other as a switch?
            Rick L.
            • toppack
              • Nov 2008
              • 1124
              Wow, 1.25"! That sounds like a Real Challenge. My Cigars are bigger than that! :D
              I'm starting to go with Idea that 'Bigger is Better' now, tho. After fighting the 'Too Small for Me' 2.5" Gato SD. :)
              I'm more accustomed to dealing with Obsolite-Antique-Technology Anyway. :D
              And I'm getting the feeling that the 3.5/2 Fits into that catagory. ;)
              I would like to see some better pictures of it, if possible?
              Is it like this, except with 2 motors and shafts installed:
              Rick L.
                • 13627
                Okay,
                That's it, just make up/break a battery terminal.
                • toppack
                  • Nov 2008
                  • 1124
                  Yep, I'm starting to get this 'Sink Your Boats' technology wraped around my brain. :D
                  The 3.5/2 does have 2 motors doesn't it? Or is it just 1 motor geared to 2 prop shafts?
                  Rick L.
                  • Nuke Power
                    Banned
                    • 277
                    The mod 2 comes with two 12volt motors with independant 3:1 gear reductions.
                    • toppack
                      • Nov 2008
                      • 1124
                      Thanks, Rogue
                      Getting this Info from Mike and David is like 'Pulling Teeth'. :D
                      Rick L.
                      • Nuke Power
                        Banned
                        • 277
                        Like I have said before... I usually have the answer, just ask.
                        • toppack
                          • Nov 2008
                          • 1124
                          Since I'm getting that huge 3.5" SD for the T-class, I'm thinking about putting a computer in it and make it automated, robotics style, with sensors monitoring everything. :) With manual RC mode as backup.
                          What do ya think?
                          Rick L.
                          • Nuke Power
                            Banned
                            • 277
                            There is a special effects guy out of california that has a sub like that. The entire thing is see through plastic so you can see al the functions as it goes. It has a fiberoptic periscope that he can lock on to tagets and the boat wil track them. Cool beans.
                            • toppack
                              • Nov 2008
                              • 1124
                              I'd sure like to 'Pick his Brains' for Info.
                              Don't suppose he's on the Internet anywhere, Is he?
                              Rick L.
