Question for HWSNBN Reg. Marking Jig and Holding / Supporting Jig
  • george
    • Dec 2010
    • 731
    Hello
    I hope you HWSNBN will be willing to help with some building jig tips. Due to my starting health hand issues, others here maybe have similar issues.
    I think I remember seeing you showing jigs that you created for working on hulls.
    1. Was a marking jig that you pulled across the length of a Nuk hull to mark the cut line as well the water line.
    2. A jig you used to secure a hull so you could cut the hull top for it to be the point you install the WTC into the hull.
    3. Last one I remember you using a Dremel with a razer cut disc in it and dragged across the hull in a jig to cut the access top of the hull.
    Would you please show pictures of the parts above please. Would the holding hull jig #2 ONLY be used for Nuks or can it be used for WWII subs as well?
    Again Thanks for your Time and Help here.
    George
    • 13605
    Originally posted by george
    Hello
    George
    A jig -- referred to, in some cases, as holding fixtures -- secures the work with the subject's longitudinal line parallel or perpendicular with the jigs/fixtures base. These holding devices permit both layout marking, scribing, and simple machine operations (drilling, milling, and cutting, to name a few) with acceptable precision. Such tool are indispensable for assuring proper alignment and even distribution of appendages to the main body of the work. Some of the jig/fixture tools presented below are suitable for bodies of revolution and asymmetrical forms.
    ​​​​​​​David​
    • george
      • Dec 2010
      • 731
      Wow, Thank You Very Much for sharing those fixtures/jigs.
