Caswells mini digital underwater camera
    • 2617
    #46
    This sounds the same procedure as setting the date and time on the 808 cams. Using a normal text editor e.g. wordpad create a text file named 'time.txt'
    Write the time and date you want to set your camera to. Make sure the time is a few minutes in advance.
    The format you write this in should be shown in the instructions, but if it isn't, looking at your videos it's likely to be-
    year.day.month hour:minutes:seconds
    Save this document onto the root directory of your cameras memory card, then insert the card back into the camera. Switch on the camera at the exact time you wrote into the text file (this is why you want to write the time a few minutes ahead.) and the time and date should be written to the camera memory.
      OH MAN! Ill have to get our IT guy down here to help me with this one!...............................Stay tuned
