Speed Control
    Speed Control
    The specs and size seem to be good for subs. It’s the same one used on my Fletcher destroyer. Pushes a lot of weight and two motors.
    Length 72mm / 2.80in
    Width 42mm / 1.63in
    Height 17.5mm / 0.68in
    Weight 89g / 3.18oz
    • 2642
    120A, why such a high current rating?
      Couldn’t advise.
        That’s humongous. Pretty awesome if you have the call for a gigantic motor, but it would be a tight fit in all but the biggest cylinders…
          • 2642
          Most small esc’s aimed at the quad copter fraternity will run to 30-40a these days, and they’re very small.
            • 898
            Yikes! One of these on the highest setting (1.5HP) only draw between 35-48amps
Name:	Screenshot (911).png
