Ice Station Zebra - Under the ice scenes model filming setup?
    • 1622
    #31
    My reading takes me all over the place. Including Surface at the Pole. Capt. Anderson gets a bit long winded, but over all it’s a good book about the Nautilus’ failure and triumph.
    • RanSan
      • May 2020
      • 61
      #32
      In that case, you guys are all set. Scan the drawings to CAD files, then set your godless 3D spawn-of-Satan machines about their work.
      Mr. Merriman,
      How would one persuade you to allow them to see your drawings to create 3d files for one of those spawn of Satan machines?
      Respectfully,
      Randy
      • jphatton
        • Jan 2021
        • 107
        #33
        Randy,
        As noted above the USS Sargo webpage has a basic set of drawings, including sections and internal external profiles. Here is the direct link to the page
        These are probably a good starting point for constructing a model, taking into account any distortion from when they were scanned. This is apparent on some of the drawings, so it is always good to try to identify what are the most accurate reference lines on the drawing for model and adjusting the section positions and dimensions accordingly.
        Hopefully David has more detailed data to help with the model.
          • 13836
          #34
          Originally posted by RanSan
          Mr. Merriman,
          Respectfully,
          Randy
          This is how:
          1. you return the package to me complete with my originals, not copies, once done with it.
          2. you consider producing and sending me model parts so I can cobble them together into proper masters from which GRP tooling can be derived
          3. I acquire unrestricted private and commercial use of all model kits, produced from that tooling. That agreement, if made, in written form.
          I'll need your complete mailing address -- send it to me at my e-mail address, if you wish. dmeriman@aol.com
            • 814
            #35
            This is how:
            I'll buy one ready here!
              • 814
              #36
              MORE ISZ Stills enhanced. No chnage in lighting or colors. DVD lift Images sharpened a lot &resolution change from 200 Pexils per inch to over a a 1000. Consistent in all ISZ images in this thread. USS Pickerel (SS-524)
              Click image for larger version  Name:	mPBTLuj.jpg Views:	0 Size:	49.4 KB ID:	174102Click image for larger version  Name:	WvCDHD2.jpg Views:	0 Size:	49.8 KB ID:	174103Click image for larger version  Name:	tXJJDSV.jpg Views:	0 Size:	51.0 KB ID:	174104Click image for larger version  Name:	nM0nXzX.jpg Views:	0 Size:	78.5 KB ID:	174106Click image for larger version  Name:	vEFHfyy.jpg Views:	0 Size:	48.3 KB ID:	174105Click image for larger version  Name:	AIiWANb.jpg Views:	0 Size:	45.8 KB ID:	174107
                • 814
                #37
                MORE ISZ Images
                  • 814
                  #38
                  MORE ISZ hope it helps
