Centering servos without using a servo driver/tester
    Is there a way to center the servos inside a 2" SD using just your radio? Thanks
    Not that I am aware of redboat. You can use your trim controls on your radio to make an adjustment.
      • 13982
      Thing is called a 'servo-setter'. A knob on the device, when twisted, sends a signal straight from its square wave pulse generator to the receivers amplifier.
      A calibrated scale under the knob tells you when the signal is neutral or any degree from zero, left or right. Disconnect the servo lead from the receiver and hook that lead up to the servo-setter, and twiddle away. You'll need a 4-5 volt power supply -- the same battery pack used to power the receiver and other devices that draw power off the receiver bus.
        But Dave, will the servo stay where you have set it with that tool or will it revert to its manfg. Nuetral?
          • 13982
          Only if you unplug it while in the last commanded position.
          Once you plug that servo into another system, that servo will move it's bell-crank wherever it's commanded; the servo will drive in the direction and amount needed to null out at the commanded position signal -- neutral if the channel is squirting out a pulse 1.MS long.
            Uh Dave question was centering a servo without a servo tester...
            Know what you're gonna say. Get a servo tester ******!
            So I bought this on eBay last night
            http://cgi.ebay.ph/ws/eBayISAPI.dll?...E:L:OU:PH:1123
            should be here in a few days.
              • 13982
              OK, smart-guy:
              Grab the servo bell-crank and twist away ... and hope you don't chip gear teeth.
