The M1 Disaster
    The M1 Disaster
    Yes, most people are aware of the original M1 disaster, but my M1 model has also had its fair share of problems.
    Mr. Merriman was sent the original molds I had purchased, and after he'd cast his beady eye over them, he returned them via UPS. They never got here. Arghhhhhh!
    Luckily, I still possessed an un-assembled model, so, with advice from His Eminence, I thought I'd have a go at making a new set of molds.
    Firstly, I bought a 5' x 1' melamine shelf and screwed a piece of 1" x 6" soft pine to it at right angles.
    The object here is to copy the profile of the model onto the pine board. I needed to be able to draw the line evenly and pondered how to keep the pencil horizontal as I dragged it along the side of the boat. After sleeping on it, the light bulb came on. If I placed the second half of the model alongside the first, I could strap the pencil to a long rod and place it over both models, which would keep it level. It worked like a charm.
    Next job is to cut out the profile with a fret-saw.
    So what happened with UPS? I dont agree with the US Mail system and UPS as well that you have to buy insurance to cover for loss. By my way of thinking, they took charge of your item and recieved payment from you to ship it, therefore the responsibility for its safe arrival should be theirs!...................Rant over.
      Well, someone, he who shall not be named, but we all know who the W anker is, only insured the molds for $300. Whats more, it was shipped on my nickel! Anyhow, they lost the package in Syracuse (it was ALMOST here). So thats it. I lost the entire setup - G O N E! I could spit.
      Boo! Hoo! Hoo!
        • 13983
        I'm such an ASS!
          Originally posted by Merriman
          I'm such an ASS!
          Turn around! I want to see those bus tire marks all over ya!
          Ha! Ha! Ha!
            • 2641
            That class of boat appears to be cursed even in miniature form!
              • 13983
              Indeed, Andy.
                Yes, there was a lot of cursing when I found out the model had evaporated into the UPS black hole.
                  • 13983
                  Mike taught me a trick there ... the use of the two halves as a means of holding the stick-assisted pencil parallel as he marks out the vertical plane parting board. Good stuff, Mike.
                  Now, repeat after me: "These are not the Droid's you are looking for ... these are not the Droid's you are looking for ..."
                    Yes, I know - I'm impressed with me too!
                      • 13983
                      Yes, Mike. Even a broken clock is correct, twice a day.
                        Hah! Listen pal, did I ever say I was a model maker? Do I want to be a model maker? No! Why am I doing this? Because if I waited for SOME model makers, we'd be here in the same position next Christmas. Good grief! He's on his favorite
                          • 13983
                          Ah ... er .... ah ....
                            Er! Moving on ......
                            Firstly, I filled the hulls with Crazy Foam, and placed some blocks of wood into it, to enable me to screw into the hull and pull it onto the melamine board.
                            I cut the profile out of the pine board and screwed it on top of the 1/2 hull. There was a gap between the board and the model, so I filled that with modelers clay and smoothed it out.
                            Here is the completed article, duly coated with Carnuba wax and silicone.
                            The next job is to lay up epoxy and fiberglass tape in stages, to ensure the edge detail of the mold is captured correctly.
                              • 2641
                              Won't silicone inhibit the cure of the resin?
