SUBES2 Switch-Question
  • ADDINGTON
    • 80
    When using this switch to control both vent solenoid and pump, do those devices have to use the Positive (+) output from the switch, or can I provide (+) to the devices directly from the main battery positive(+) and simply use the switchable ground (-) ES2outputs to complete the circuit and energize the device ?
    Thanks,
    Kerry
    • 2641
    If the subtech unit is happy to switch positive or negative loads, that will work fine.
      • 13984
      Just make sure you get the polarity right on the input side of the switch (batter-to-switch). The DC brushed motor and solenoid don't care about polarity (unless motor direction is an issue).
      • ADDINGTON
        • 80
        Roger that-the pump motor direction is crucial so I will take polar care.
        Thanks David.
        • Rpmtech1
          • Dec 2009
          • 229
          That switch is a jalopy, it takes like 5 seconds for it to respond LOL.
