Spent a number of hours searching for some low kv rated 28mm brushless Outrunner motors today. Mainly I am after motors capable of spinning lower rpm’s for directly driven prop shafts.
All the typical airplane and drone websites had listings for brushless Outrunner in this diameter but most of these motors still had kv ratings in the 1000’s. Lowest I could find was about 700kv in a 28mm OD.
By dumb luck I stumbled upon some random listings on amazon for some 28mm 350kv and 500kv brushless Outrunner motors. Here’s a couple links.
It appears these same motors are used in a number of thruster pod products available from a number of different sellers.
I picked up a couple to test them out. Posting because I figured this might help someone else out.
Nick
Nick
