More uses for Caswell/Merriman ADF
  • RonP-UK
    • Feb 2010
    • 67
    I guess it is no secret that I am not a big fan of gas systems, its not that they dont work you understand, they do and David Merriman has proved that time and again. I have built them in the past with great success but the truth is I am just too tight to pay for the gas.
    I make my own piston tanks with one at the front and one at the rear and having boyancy for and aft makes a large boat much better when on the surface. I was lucky anough to win an ADF in last years competition so I put it in my little Alpha to try it out but with a difference. I linked the rear vane servo to a set of mico swithches that cut out the tank that is either filling or emptying first so as I submerge or surface the tanks maintain level trim without any messing about with bits of lead. Now the great thing is that by using the manual overide I can adjust surface trim by simply moving the vanes up or down and this automatically adjusts the tanks, I can then put vanes back to neutral and as soon as I dive the tanks sort things out. My party piece is to put a 4 oz block of lead on the stern but the boat will still dive and surface perfectly. LOVE IT!
    • 651
    more!..you said some micro switches, whereas only one would be needed to switch off the tank
    • Rpmtech1
      • Dec 2009
      • 229
      I have no idea what your talking about, but I like the sound of it!
      • oztruck
        • May 2010
        • 317
        So what you are saying is, the motors controlling the pistons are being controlled by the ADF to keep the boat level. As the control surface moves via the ADF it activates a switch which it turn powers one of the pistons motors to level the boat and in the opposite direction controls the other piston?
        • Rick Teskey
          • Jan 2009
          • 264
          Kevin Mcleod adf sold by Caswell?
          Rick
