I am in the process of putting together the LED lighting for my Deboers Seaview but I am stuck on one particular light location. Aside from the red and green LEDs on each side of the sail, where is the third light located? One of my sources indicates that a white running light should be mounted on the top aft portion of the sail. Is this correct? Please help set the record straight.
Seaview Lighting Question
