2.4GHz to 75MHz transmitter
  • cheapsub
    • 187
    Just a joke.
    May be not.
  • cheapsub
    • 187
    And
    This dumb dumb did the monkey see monkey do.
    • Kim Sleep
      • Nov 2013
      • 329
      Why,? there are so many 75mhz, and other frequencies that are available on EBay Euro that this is unnecessary
      • cheapsub
        • 187
        Just like stuff a V8 in to a subcompact.
        I am a one sick poppy.
        • cheapsub
          • 187
          Little up date, now works with futaba module. Just make a adopter board. no 6V regulators needed.
          • cheapsub
            • 187
            Does this count?
            is synthesized!
            • Kim Sleep
              • Nov 2013
              • 329
              We just need a step by step conversion details
              • cheapsub
                • 187
                It works with futaba too, at the banch. Need more testing. Opentx stuff.
                will try it with a hitec transmitter.
                Here we go.
                Find a working JR XS3 synthesized transmitter, not XR3!
                $25 plus shipping. At evil bay.
                gutting the transmitter, remove the bits not longer need.
                fing pin 8 from RF board (small one) , cut it . Connect it to the flysky th9x's PPM signals and power to the main board.
                still need the main board, to change the channel.
                stuff all the board in to a box. Done.
                Any questions?
                • cheapsub
                  • 187
                  More pictures
                  50/50 you may get a JR XS3.
                  https://www.ebay.com/itm/324150651009
                  https://www.ebay.com/itm/173956096224
                  This is Evil Bay after all.
                  • cheapsub
                    • 187
                    Nice Gadget to have for group run.
                    • cheapsub
                      • 187
                      Find one, but is not 75 MHz, batter then nothing.
                      the clean look that counts.
                      have to build a box for the other one.
                      It works with hitec optic 6 too [different pin in], that can change between (+) and (-) shift. Still in reverse shift. Well it works.
                      The end.
                      • cheapsub
                        • 187
                        Synthesized the dead. Click image for larger version
                        • Kim Sleep
                          • Nov 2013
                          • 329
                          Originally posted by cheapsub
                          Synthesized the dead. Click image for larger version  Name:	20201127_012545_1024x1125.jpg Views:	24 Size:	57.2 KB ID:	145343
                          See now thats smart...there are a million 75Mhz modules out there, for Pistol grip transmitters....someone should be working on how to make those work with full size transmitters
                            • 12321
                            I completely agree!!!!! I would pay serious money for such a module equipped with an interface jack. This could be a gold-mine for some smart cookie out there in tinker-land.
                            • cheapsub
                              • 187
                              Still a mystery on pin input. Airtronics doesn't make it easy.
                              Testing with futaba, hitec should be ok too.
                              9x on er9x more flexible.
                              will post if things go ok.
