What is the Proper way to make a Strong Repair of a hole in a Plastic object
  • george
    • Dec 2010
    • 731
    Hello
    I would like to know what is the Best and Strongest method to repair a fairly large gap in a wall of a plastic printed torpedo body. It will never be under internal gas pressure. I have several tail pieces that during 3D printed developed a crack/gash along it`s base section.
    I know HWSNBN uses a mix of CA and baking soda as a thick patch. Would that work and I could then sand the outer shell smooth and go from there. Also I would use some tape internally to support the filler OR is there something else that can be applied to fill this and limiting weight is also important.
    Here is a picture of what I basically have x Several.
    Thanks for your help in advance
    Originally posted by george
    Hello
    Like so:
    Or ….
    Bondo. After filing and sanding overcoat with thin formula CA to strengthen the bond.
    • george
      • Dec 2010
      • 731
      Thank You for the show and tell how to.
      Question, would thick CA also work in your lesson? I ran out of thin CA.
      Thanks Again
      George
        Thanks Again
        George
        Yes, but takes longer to cure.
        • george
          • Dec 2010
          • 731
          So you can`t use Kicker on it with thick CA?
          Just the mix of Baking Soda and thin CA with No kicker at all?
            Most of the time I use either one or the other catalysis. On occasion, when using too thick CA, I'll do both.
            • george
              • Dec 2010
              • 731
              ah O.K Thank You. For now I will get some Home depot thin CA
              Can`t wait for 2020 Toledo Weak Signals to load up on thin CA, got lots of the thick stuff.
              • george
                • Dec 2010
                • 731
                Have a line on a used vacuum pump at a Great price. Any tips on what to ask about it, I know Nothing about it for now. As for a pressure pot No luck so far locally. Keeping my eyes open.
                  Minimum flow, 3 CFM; minimum vacuum, 28" of Mercury.
                  • george
                    • Dec 2010
                    • 731
                    O.K Again Thanks for the lessons
                      George,
                      while learning to patch the holes is great, the bigger question is what is wrong with your 3D printer that it is doing that? Do you know what happened during the print job? Did the filament get tangled or the print head make a lot of noise?
                      • george
                        • Dec 2010
                        • 731
                        George,
                        Hi, No it is not my printer BUT a printer from our local area library. I think it might have something to do with the file as well as inexperienced librarians/operators. Price is beyond belief so I guess I put up with some "crap" excuse the language.
                        I got the file redone and have a new print being done as I type this. Will be back here tonight and let you know how the new print turned out.
                        Makes me want a 3D printer, dam curious thing.
                        • george
                          • Dec 2010
                          • 731
                          Well I just got back the newest version from the same 3D printer source, came out solid, no cracks, splits. Work continues.
