today's work
    • 13982
    #586
    Originally posted by bwi 971
    Thanks David!
    As you are a “Luddite” I must worn you the prototype will have been pooped out by a machine. Take some allergy medication prior and were full PPE during unboxing.
    Planned to finish the prototype end of the week.
    Grtz,
    Bart
    Warning received and understood. I'll hold my nose as I formulate my critique. You know how to test a friendship, don't you??...
      • 3758
      #587
      F you, Tom!
      If you must know, I drape myself in plaid.
      When I saw you made a post, I was ready for the blast....you did not disappoint!
      I will chuckle for the rest of the day.
      • bwi 971
        • Jan 2015
        • 940
        #588
        LOL.......the poison is in the tail they say.
        Can you PM your mailing adres David?
        Below some sneakpeak pictures of the gizmo....I will only ship the blue one.
        Grtz,
        Bart
        "Samuel Smiles"
          • 2641
          #589
          Russian Triton sub. Nice.
            • 13982
            #590
            Grtz,
            Bart
            So, a kort nozzle, ala some of the SEAWOLF midgets? a nozzle that swings (along with the fixed rudder element within the nozzle) between the two vertical stabilizers? You want me to work out a practical linkage to rotate the nozzle?
            Me like.
              • 13982
              #591
              David Douglass Merriman lll
              835 Holly Hedge Ave.
              Virginia Beach, Virginia 23452
              US of *** A
              dmeriman@aol.com
              third from the sun
              Sol system
              Milky Way
              Half-way out from the Big Bang
              • bwi 971
                • Jan 2015
                • 940
                #592
                Me like.
                Russian midget
                Nozzle functions as you indicated
                I already worked out a linkage, it will be included, it is partly external of the hull.
                It would be great to have a second opinion, maybe you see possibilities to have it all concealed within the hull perimeters.
                Imo the latter will be too complicated to maintain for a novice person.
                You can destroy it after you have a look at it David, how is that for a friendship gift, smashing up a pooped out gizmo?
                Heat is also a PLA killer.
                Grtz,
                Bart
                "Samuel Smiles"
                  • 13982
                  #593
                  Russian midget
                  Grtz,
                  Bart
                  I love it.
                  When it gets here I get to play Rube Goldberg (my personal Savior)
                  When I've worked out a credible linkage I get to destroy that 3D printed spawn of Satin with a Martian heat-ray I have left over from another consulting job.
                  Life is good!
                  • SteveNeill
                    • 315
                    #594
                    Thank you for my morning tea video. Life makes sense again David. I bought a 3D printer. It was never sent. I was out a few 100 bucks but saved from the demon. I took it as an omen. Never tried to get one again. My built in 3D printer managed this OK. Click image for larger version
                      • 13982
                      #595
                      Dodged a bullet, Steve. Keep the Faith, pal.
                        • 13982
                        #596
                        Last year the great hull fabricator, Richard O'Malley and I agreed to work up USS NAUTILUS (SS-168) kits so we can jointly terrorize the skimmers providing target services at the NC 'fleet-run'. Richard is well underway on the hull, and I've just started work on the appendages. Here's my contribution so far:
                        My work started after receiving a beautiful orthographic drawing of the NAUTILUS prepared by the Polish historian, Stawomir Brzezinski for Richard. I checked it against my sources and was delighted to see that Stawomir had likely used the BuShips 'Booklet of General Plans' as source -- most aspects of those documents were in agreement. A real confidence builder.
                        A very good start; Richard had secured the 'good stuff'! While Richard was doing his magic to produce the 1/96 hull master I set to work on the appendage masters. The list of things to make included: bow planes, sail, shears, guns, stern planes, rudder, and gun-deck. Today I stated with slapping together the RenShape blanks for the rudder, bow planes, and stern planes.
                        As is my practice I mount the drawings on a 'billboard' that will keep the documents flat for accurate lofting. The billboard permits me to move, in mass, all the orthographic documents relevant to the job around the shop or to just to get the damned thing out form under foot when it's not needed. Sorry about the fruity sweater, a joke birth-day gift by my smart-ass daughter! She's been a button-pusher from day one.
                        As Richard sent me the plans folded I had to iron them out to eliminate the creases. I also cut away dead space to reduce the total footprint of the plans. That work done I secured the drawings to the billboard with clear packaging tape. Now: to work!
                        The ideal modeling medium is RenShape, for detail I use the medium-hard 40 lbs. per cubic foot stuff. I broke out a box of end cuts and worked some of it on the band-saw to come up with the control surface master blanks.
                        When shaping symmetrical structures it's wise to laminate two halves of a blank together after darkening their glue-side faces with black marker or paint. Doing so, no matter how much material you work away from the edges, you always have the centerline evident to guide you as you work both sides to the correct section -- in these masters, a tear-drop shaped hydrofoil.
                        Screw it. Enough. I'm hitting the rack!
                        • Monahan Steam Models
                          • 755
                          #597
                          Looking forward to this build!
                            • 13982
                            #598
                            Me too. This long deferred project is one of he reasons I retired this year. A bucket-list item that must be addressed.
                              • 13982
                              #599
                              A brief recap on the 1/96 STURGEON master and tooling work I'm doing for the Nautilus Drydocks in support of the kit they will be coming out with in a few short months.
                              Keep in mind that this installment has little do do with the master and tooling work, but instead chronicles the work I've done so far on the 'check-model' I'm building to affirm the fit and detail capturing of parts produced from production tooling.
                              Previously I had bonded the resin tail-cone to the GRP lower hull. And that left me with the task of fairing in the radial seam between the two structures, initially with Bondo. After sanding that smooth, I switch to Nitro-Stan air-dry touch-up putty, sanded that, and then sprayed on the first check pass of gray primer.
                              I didn't bother priming everything, just the recently opened up holes in the bottom and upper hull halves, as well as the before mentioned after radial break between stern-cone and lower hull; and the forward radial flange of the forward hull. The gray primer identified flaws that required filing or filling, and the process repeated.
                              Radial seam? What radial seam? I don't see no radial seam!
                              I was glad to see that the fine engraving I had applied to the hull master was not only faithfully captured in negative by the glove-mold, but was also imparted faithfully onto the check-model. Can't do engravings that deep and narrow with a hard-shell type tool.
                                • 13982
                                #600
                                I always endeavor to make a model submarines sail as interesting as possible. That means representing all or most of the boats extendable masts and fairings as possible. You see that done on these models I did, both in 1/96 scale -- like the STURGEON masters and tooling I'm working on now. The finished one showing THRESHER, the unfinished one the WEBSTER (my second boat to have served on).
                                I install the masts and fairings when the model is on display, but will leave them on if I'm to operate the boat in 'safe' waters -- that is to say, I'm not running through surface formations and acting the fool as I play cat-and-mouse. If I'm froggy I leave the removable items in the tool-box and put a single 'sacrificial' mast on the sail I have something to see when tooling around at periscope depth.
                                If the masts and fairings are to be removable AND are to all stand tall and straight each has to be support at two points. Typically a mast or fairing is supported at the top of the sail (or a point just within the opening at the top through which the mast would project), and another fixed support structure farther down in the sail. I've found the minimum distance between these two bearing points to be one-half-inch.
                                I'm tired, it's late, I'm hitting the rack... you got questions about how I do it? Ask! Here are the pretty pictures.
                                Nighty, night!
