the SubDriver becomes modular
    I would add a channel to the vent, I did not put that in.
    If I get what Scott is saying, Incorporate your vent into the bulkhead. I drew up this as an example:
Name:	Screen Shot 2019-10-28 at 3.54.54 PM.png
ID:	134616Click image for larger version
Name:	Screen Shot 2019-10-28 at 3.54.10 PM.png
ID:	134617Click image for larger version
Name:	Screen Shot 2019-10-28 at 3.53.22 PM.png
ID:	134618 The downside is that you would need to route out the cylinder to fit the vent. It is a wet side so a o-ring is really not needed, you could just run a beed of RTV silicon.
    Does this make sense? Scott is this what you meant?
    Tom
    Now, that concept has merit. Let me mull over this idea. Neat!
    Tom
    Originally posted by Scott T
    If you made the vent hole part of your casting you might be able to remove the ballast tube without fiddling with the vent.
    This would make adding longer or shorter ballast tanks simple push on pull off procedures.
    Incorporating your vent into the bolt on section would reduce your part count as it would not be a separate cast piece and
    need attachment to the tube. I have a drawing but cannot upload it for some reason.
    Also your private message area is full and will not take anymore messages.
    Will try to send the picture tomorrow.
    Thanks,
    Scott T
    Looking forward to your input, Scott.
  • Scott T
    Thanks,
    Scott T
    David, again another exceptional documentary on how you do things. Do you put the half mold in a pressure pot at all?
    Thanks, Tom. Nice to be appreciated by a peer.
    The only differential pressure needed to get rid of the entrapped bubbles (some a consequence of the exothermic reaction, but most folded in air by the mixing process) in the rubber is to subject the still 'liquid' mix to a hard vacuum that increases the gas bubble size to a point where buoyant force drives them to the surface where they break and the gas evacuated by the vacuum pump. De-airing/de-gassing. The mix is brought back to ambient pressure and poured over the masters.
    If you don't have a hard vacuum source then you pressurize the poured rubber to at least one-atmosphere for the duration of the state change.
    Bull-**** Artist
    Specialized sanding tools were used to reach into the flat and vertical surfaces within the two union master halves: One type of tool for the flat surfaces, a sanding disc; the other for the vertical, a sandpaper wrapped dowel or twist of sandpaper.
    By the way, whenever possible, I wet-sand the work. The water helps to keep abraded material from clogging the surface of the abrasive.
    The right side of this union master half (the ballast tank side) has already been sanded using the specialized tools. The left side is still in the raw, its puttied surfaces yet to be worked with abrasives. What complicates this particular sanding job is the need to preserve the small radius fillets between foundations, gussets, and the flat internal face of the master. That’s why the sandpaper discs are secured to a piece of rubber sheet – giving it the flexibility to ride up the fillet radius, following its contour, not cut into it.
    This is how the sanding tools for deep flat surfaces (and surfaces that transition from horizontal to vertical through fillets) are made. A round handle (shank, if you will) has glued to its end a disc of soft rubber, to the face of that rubber disc is glued a disc of sandpaper. Each of these tools has a disc of #200 grit sandpaper at one end, and a disc of #220 sandpaper at the other. Note how the edge of the rubber and sandpaper disc extends slightly past the diameter of the tools shank – this permits the flexible rubber to bend, and along with it the sanding disc, permitting the sandpaper to ride up and conform with the curvature of a fillet. Neat!
    Note the brass-tube cutters used to punch out the rubber and sandpaper discs.
    Some of the sanding tools I used to smooth out the Bondo and Nitro-Stan filler and putty. The surfaces at right-angles to one another, joined with tight radius fillets presented a special challenge when it came time to abrade them smooth.
    The handle/shank of each tool is round, be it wood dowel, PVC tube, or acrylic rod. Whatever is at hand.
    The touch-up putty was carefully abraded back and primer applied. Problem areas got more putty and sanding, and priming – the process continuing till everything was nice and pretty.
    Steel wool and 3M abrasive pads are excellent abrasives that get into tight radius corners and deep wells, such as presented by the two union master halves. Where fingers can’t reach, hemostats can. These fine abrasives used only on the primer. The course work gets the sandpaper treatment!
    A quick job of buffing the cavities within the master halves was done by spinning a hunk of steel wool, at slow speed, with the aid of a variable speed electric drill.
    The two halves of the union master being prepared for creation of the rubber resin casting tool. This will be a two-piece tool. Footing the masters in a layer of clay secures them in place. Additionally the pliable clay is the perfect medium for pressing the dimples that will give form to the indexing network at the flange line between the two eventual tool halves.
    The containment dam for this first half of the tool is simply a wrap of masking tape.
    So, how much expensive rubber to prepare for a specific job? A great cheat to determine the exact volume of rubber needed is to substitute a liquid, like water – pouring in the amount needed to cover the masters, and then pouring the water into the container you’re going to mix the rubber in and marking off the waterline within. That waterline mark denoting how much catalyzed rubber you need.
    Second best cheat, and less messy, is to substitute rice for the water. That’s what I’m doing here.
    RTV platinum cured silicon mold making rubber is expensive. Rice ain’t.
    Here I’m pouring the first half of the rubber tool. The two-part tool will give form to the cast resin production union parts. This single tool produces both the forward (ballast tank side) and after (dry space side) of the union.
    Before pouring the catalyzed and thoroughly mixed RTV rubber over the masters – that process invariably folding in a lot of little air-bubbles into the mix, the mix was de-gassed by subjecting it to a hard vacuum for several minutes.
    Though the radial flanges of this union master are too over-sized to fit the inside diameter of the Lexan cylinders – the over-size to account for later tool and part shrinkage – I laid out the cylinders to give you a better idea of what the union piece is all about: a means of joining two separate lengths of cylinder; the union piece affording the ability to size the after dry space and ballast tank to suite a specific need.
    I’ve mocked-up operation of the union by inclusion of the ballast sub-system servo and its pushrod, and temporarily pinning the pushrod seal and emergency blow valve foundations within the face of the forward union half. If the outfitted master will work, so will the eventual cast resin production unions.
    The after dry space side of the union required a little milling to produce a well to provide clearance for ballast sub-system servo bell-crank travel. Other than that the majority of the machining was done on the lathe and drill-press.
    Though what I’m building is a master from which tooling will be made -- from which production union parts will be cast from polyurethane resin -- I do make the master a fully operable device. If I can’t get the master functional, then how can I expect the castings to be functional?
    Case in point is the ballast blow/vent linkage, which is actuated by a little ‘mini’ sized servo. The pushrod travels through both halves of the union and is made watertight at the ballast tank side of the union through a pushrod seal that mounts at the forward end of the pushrod seal foundation.
    Here I’m using a servo-setter to check for unbinding operation of the pushrod through the extreme throws of the servo bell-crank. The machining I did in the above photo was to dig out that square shaped well in which the servo bell-crank travels.
    To the left are the things that fit to the face of the after, dry space side half of the union: the ballast sub-system servo, servo strap with attached low pressure blower limit switch, and pushrod. To the right is the forward ballast tank half of the union which is yet to have permanently attached to its face the emergency blow valve and pushrod seal foundations
    Though not envisioned to see much use, I am providing in the union halves a ¼” hole to accept the after end of a conduit – through which power cables would run – if the end-user decides to graft, through another simpler version of the union, the forward battery space directly to the forward end of the ballast tank.
    Most users will elect to simply plug the conduit hole and house the battery in a separate length of cylinder.
    Note the marking stencil, made from clear acetate sheet, used to guide me as I drilled out the holes for the five machine screws used to compress the two union halves together when assembled.
    Cutting in the O-ring grooves to the radial flanges of the union. The watertight seal between Lexan cylinder and union will be accomplished with the aid of two O-rings for each half of the union. Right after this operation I sawed the union into its respective halves.
    A recent addition to the SAS type ballast sub-system was the substitution of a mechanical limit-switch for the electronic motor controller that formerly operated the low pressure blower. You see the limit switch mounted to the servo securing strap. As the servo bell-crank travels to the ‘blow’ position it closes the limit-switch which completes the circuit to the motor, starting it pumping air (either coming from the SD dry spaces or through the broached snorkel) into the ballast tank, pushing the water out.
    You see to good advantage in this picture the square milled well that provides clearance for the servo bell-crank when it travels to the extreme ‘vent’ position.
    The two halves of the union will be secured with five (initially I planned on eight, but things got too tight within the union for that) 4-40 flat-head machine screws. I have yet to cut in the O-ring grooves that will make things watertight within the tight space between the two union halves.
    Within the forward half of the union .080” Sintra sheet was used to make the three gussets that support and improve eventual resin flow through the tool used to cast the resin production parts. Once glued in place the base of the gussets as well as the two foundations were given Bondo fillets. I used one of Mom’s old dapping tools as a fillet tool, assuring a constant radius fillet all around. After wet-sanding the fillets with a twist of #100 grit sand paper I coated the work with Nitro-Stan air-dry touch-up putty. And after that dried I wet sanded the work with a twist of #220 sand paper. This made the work ready for primer.
    Originally posted by type7
    I was just thinking, if the ballast servo bulkhead became one side of the battery compartment with air pump inside, then the ballast tank can be a completely separate module just by adding simple end caps. Just need a 3 or 4 wire harness.
    Since I have a lot of running subs, I have played around with using an easy driver with a 3 wire connection to a completely separate ballast tank. Need to refine it more this winter but it seems to work.
    Looking forward to seeing what you come up with. I've made it clear what I'm coming up with; I've shown you mine. Now, show me yours.
    Gauntlet thrower par excellence
  • type7
    This is an exciting development, a great evolution. Will the 2 parts of the wtc have to be mechanically connected or just by a waterproof electrical connector?
    If you mean between the after dry space and the ballast tank, no mechanical or electrical interface -- the mechanics are within the union piece. If you're talking between the module proper and the separate battery compartment, the only interface is the power cable running to the wet side of the motor bulkhead.
    In Whacko Mode
  • type7
    Damned spanky start to a project that I"m really looking forward to.
    As a bit of background, basically every boat has a bespoke cylinder to match to it, mainly due to the size of ballast tank needed to bring it to proper surfaced waterline. This is great for sales, as you all need to buy a separate cylinder for each boat. I have to order and stock all those things, which is exceptionally painful to my poor bank account.
    What David and I are envisioning, is a modular approach that will allow one motor section, for example, to mate with a myriad of other ballast tanks and battery compartments, resulting in a ton of flexibility for you guys to tailor the cylinder to your needs. This also means that a single motor compartment could fulfill the needs of a half dozen boats instead of only one.
    Another feature we're playing around with is staging up the ballast tank diameter so that it can be as short as possible.
    Lots of options, opportunity and exploration to do. Obviously, David is the man to get it done. I'm anxious to see what he comes up with!
    Here, the union master, mocked up and shown next to a cast resin after ballast bulkhead production part. Note how they share the same seal and blow valve positions and function.
    There is no need for a conduit hole through the union, as the separate battery compartment will provide power to the SD through externally running power cables. There will be no conduit running the entire length of the modularized SD’s ballast tank.
    As there are no mechanical fasteners (only a tight wrap of Electrician’s tape) securing the Lexan cylinders together over the union, I’ve eliminated the occasional problem of cracking of the Lexan -- those fractures originating where fastener holes and fastener pressure cracks the Lexan. No holes, no cracking! Note that a watertight seal between union and cylinders is achieved with O-rings, as is the area between the union halves. The union halves will be held together with eight 4-40 X 3/4” flat-head machine screws.
