433mhz anyone
    • 898
    433mhz anyone
    I was wondering how 433mhz does under water...I am considering building a very simple static dive micro sub and using a 433mhz 4 channel switch to operate it-they are small and cheap enough and they have the benefit of rolling frequency security. I'm sure not as good as 40mhz and I hope much better than 2.4ghz.
    Been proven to work, but how well the system you use will work depends on the wattage of the transmitter.
      Bob, a gentleman named Tim Senecal has pioneered using 433MHz in our slice of the hobby. He has done some amazing things, but the simple answer is yes, it will work.
        • 898
        Well that's good to hear-I wonder what wattage these things work at and how deep will they go..
          • 898
          Thanks-this appears to be a very interesting subject-several links over in RGC were extremely informative...unfortunately I couldn't get the link in post #2 to work..
          • type7
            • 198
            I would have to look but didn't Tim Senecal post an article on 433 Mhz on Subcommitee as well? Might be duplicated info.
