5000mAh 3.7v Li-ion batteries
    • 3767
    Has anyone used 3.7v Li-ion batteries like the ones listed below?
    https://www.ebay.com/itm/5000mAh-Rec...ibZ05bd9-xfgKA
    The density seems to be great on these and I can fit them in my Gato for longer runs, maybe?
    • 2642
    A lot of these cheap 18650 cells have inflated specs. Most good quality cells of this size tend to offer capacities of around 3-3.5Ahr. If they do genuinely offer 5Ahr capacity, the current delivery is likely to be modest, as the cells plates will have to be very close together. This may alsol adversely impact the cells longevity and cycle life.
    18650 cells are the excellent for powering subs, but make sure you buy the right cell from a reputable source- there are a lot of counterfeited cells out there.
      • 2642
      This is a good 18650 cell, High C rating with decent capacity. I can't recommend a good US supplier, but I'm sure they're out there- https://eu.nkon.nl/rechargeable/1865...18650vtc6.html
        • 3767
        Thank you!
        • small sub guy
          • Dec 2009
          • 45
          Here is some info sorry about the pic size Click image for larger version  Name:	Screen Shot 2018-12-11 at 8.53.19 AM.png Views:	1 Size:	1.6 KB ID:	128831
          Click image for larger version  Name:	Screen Shot 2018-12-11 at 8.53.36 AM.png Views:	2 Size:	899 Bytes ID:	128832
            • 3767
            Mark, I can't see a thing.....do you have a link to those batteries?
