New Blueback kit
  • secrtwpn
    • Feb 2012
    • 182
    New Blueback kit
    I just received my Blueback kit. I have some questions about it. Anyone out there have one?????
    Farlan Clutters
    • 14014
    Yeah. What's the problem?
    • secrtwpn
      • Feb 2012
      • 182
      Remember, I'm an idiot with these things. But, the aft diving planes have a fixed brass rod imbedded in them. So, I was under the impression that the brass rod is inserted through the side plate and through the diving plane. I was trying to figure out how to put it together without breaking anything. It appears I'll have to cut off some of the brass rod to get it to fit......Attached is a photo
        • 14014
        OK. This is not the way I engineered the stern planes. The problem is another contractor is producing the kit parts from Dave Manley's and my work.
        Grab the brass rod, rotate it to break the weak bond between it and the resin stern plane, and pull that sucker our. Widen the bore with a .096" bit and it will provide a non-interference fit with a proper .092" brass operating shaft. Are you following my WIP on this kit? In that you'll see the use of a bottom mounted set-screw to hold the operating shaft fast during assembly to the tail-cone.
        • secrtwpn
          • Feb 2012
          • 182
          I will try that! Thank you for your patience!
            • 14014
            No problem. We'll talk you through this. Here's some motivation:
            • secrtwpn
              • Feb 2012
              • 182
              I was surprised how easy they came out!!!!!!
                • 14014
                To better illustrate how the stern planes integrate with the tail-cone:
                  • 14014
                  OK, I erred on the bore you need for the stern plane operating shaft -- use a .063" bit, not the .096" bitt recommended above.
                  Brain fart!
                  • secrtwpn
                    • Feb 2012
                    • 182
                    No problem. Thx
                    • secrtwpn
                      • Feb 2012
                      • 182
                      These photos will help alot!
                        • 14014
                        I got tons of them, Let me know where you hang-up and I'll give you photos that will point to the fix.
                        • secrtwpn
                          • Feb 2012
                          • 182
                          New questions:
                          1. How is the support for the masts attached to the inside conning tower?
                          2. What size/vendor do you use for the shaft bearing?
                          Thank you
                            • 14014
                            New questions:
                            Thank you
                            The mast foundation comprises two platforms that are bolted together -- this assembly is called (drum-roll, please!) the mast foundation. The foundation for the scopes and masts is attached permanently within the top of the sail with thin formula CA. BUT!!!!... only after repeated test trials and alterations to get all the masts and scopes to run parallel to one another and perpendicular to the top of the sail. The side-to-side orientation is in reference to the sides of the sail; the fore-aft orientation is in reference to the sails trailing edge.
                            When done properly you wind up with this: an ability to remove the masts to suit your taste and what you would expect the real things to be doing while you blurt out chugging and alarm sounds as you fumble at the transmitter sticks.
                            The shaft journal-thrust bearings are sized to run a 3/16" (.137") diameter shaft through a non-interference bore. They are flanged. Available from McMaster-Carr. Some examples
                            • secrtwpn
                              • Feb 2012
                              • 182
                              I noted on your WIP that the end of the upper hull is sanded/ground down to thin it out to match the tailcone. Wouldn't this weaken the area where the screw goes to attach the upper hull?
