I connected up the ES-1 switch on the test-bench and it worked, but the circuit works differently than I expected.
I used a 5.volt power-supply for receiver and ES-1 power, and another power-suppy for Load power. The load consisted of 12.v light-bulb and a resistor in series with it, to limit current.
The problem is that I found that the load had about 10. volts applied, not what the load supply was adjusted to, which was 5.v also, so the circuit Adds the 2 power sources at the load, somehow.
I wanted to connect it that way so Snort pump would be drawing current directly from battery-pack not from receiver's 5.v regulator, but looks like I may not be able to do that since voltage at pump would be too high and it appears the pump would still be drawing current from receiver supply(or V-reg)?
I need to study my circuit more and figure out what's Goin' On. ;)
