Thresher/Permit class large sail plans
  • cookiemonster
    • Jun 2017
    • 6
    Hello people,
    I am currently building a Permit class sub in 1:350 scale.
    I want to build the USS Greenling and the Greenling had the large sail.
    My kit only has the small sail and I could not find any plans or drawings that I could use to extend the sail.
    I hope you guys don't mid helping out a plastic pleb that only builds static kits.
    KInd regards,
    cookie
    • 12290
    Originally posted by cookiemonster
    Hello people,
    KInd regards,
    cookie
    I have good drawings of the GATO (PERMIT/THRESHER class). Is that the sail you need? There were several variants.
    • cookiemonster
      • Jun 2017
      • 6
      Hello David,
      Yes, that's what I am searching for!
        • 12290
        Hello David,
        I'll start digging tonight.
        • cookiemonster
          • Jun 2017
          • 6
          Hello David,
          Did you found something already?
          Cheers,
          cookie
            • 12290
            Hello David,
            Cheers,
            cookie
            Yup
            • cookiemonster
              • Jun 2017
              • 6
              Hey David,
              That is aweseome!
              But I have to lenghetn the existing sail by quite a lot. Let's see how that'll turn out.
              If I got it right I will post the pictures here.
              Thank you very much,
              cookie
                • 12290
                Hey David,
                That is aweseome!
                cookie
                If you get it wrong .... POST IT HERE! Damit. How you gonna learn if you keep your homework away from me.
                Start with a new sail -- scratch-build time. You want a hunk of RenShape to get started?
                Here's how:
                • cookiemonster
                  • Jun 2017
                  • 6
                  That's a quite impresive sail.
                  I still have to lenghten the hull, that's about 8mm in 1:350 scale. Maybe you could explain me how I can scale the plans up to my scale, I never did that before.
                  Cheers,
                  cookie
                    • 12290
                    Cheers,
                    cookie
                    Divide the denominators. The resulting whole (or fraction) number is the ratio of conversion. Express that as a fraction and you have the enlargement/reduction amount between plans.
                    • cookiemonster
                      • Jun 2017
                      • 6
                      I mean how can I do that in a image editing program like Irfanview.
                        • 12290
                        Beats the **** out of me, pal.
