Never before published uboat pictures
    If any of you are wondering whats going on with the Uboat that has all the Big Slices thru the superstructure and the damage to the conning tower, then the caption says that it was inflicted on U-35 by the German pocket Battleship Admiral Graf Spee. They must not have been playing nice. This happened on the 17th of June 1938. Damage was from the battleships portside screw and rudder.
ID:	116396Click image for larger version
ID:	116395 Todays postings: Click image for larger version  Name:	never before published 025.JPG Views:	1 Size:	26.7 KB ID:	116397
        VonHilde is probably salivating already and he hasnt even seen them.
        Shiste! What a score. Got to get that book myself Mark.
          I put the pictures in one at a time as before. Since you made changes a couple of months back, when I posted pictures Ive never had to go back in and change anything. They always were immediately large. Tonight I loaded them up as usual and one was big and all the others were tiny icon size pictures. So I went into "Edit" and clicked on each one of thems "large" button then hit save.
          I noticed that sizing problem in the past,then when I posted yesterday they were small. Thought it was because I have been using my IPad, and not the PC
            The cover photo supports the thought I had about late war Type XXIII being very dark. You can see it is not black, but uber dark gray (grey for our friends across the ponds).
            Most boats were schwartzgrau after Late 43. The camouflage schemes were dropped because after that May-June, when Doinetz lost his son, the operational orders changed, and boats were to be submerged during daylight and surface attacks were dropped, as well as the 88mm guns. u505 was that color when captured, almost all the schnell nose boats were dark as well. I would venture to guess the type XXIIIs were mostly dark as well as the Sehund and the XXIs Never could understand the snowflake camouflage. It didn't distort the silhouette, for surface targeting like the splinter stripes.
              UhClick image for larger version  Name:	image_32928.jpg Views:	1 Size:	37.1 KB ID:	116475Click image for larger version  Name:	image_32927.jpg Views:	1 Size:	52.3 KB ID:	116474Click image for larger version  Name:	image_32925.jpg Views:	1 Size:	44.2 KB ID:	116472Click image for larger version  Name:	image_32926.jpg Views:	1 Size:	44.3 KB ID:	116473 UThe U 35, "the bad luck boat" 2nd flotilla,"Saltzwedel" commissioned 2 March 1936, pictured. Type VIIA. In 37 was run over by a freighter. Graf Spey, ran over her during maneuvers in 38. Then same year ran into U 30, Airplane crashed into it in 39. It was Otto Kretchmers first command. Otto was almost drowned, when he was topside, the WO took her down and was washed overboard. Boat was scuttles 29 Nov 1939. Lot of famous guys at the commission picture.
                Kinda like Pokémon......"gotta get me all"
                • Scott T
                  • May 2009
                  • 414
                  U35s bad luck sounds better than being sunk!
                    luck was so bad, the Germans sunk it in 39.
                      Hummm.....superstitious lot I'd say
                        I just received three more back issues with four more on the way. Should produce some good new pictures. One of them has a spread on the type 21
                        i hate when the phone puts words in my mouth. The Beeatch thinkx she runs things around here. Eye, no hou ya spelt dem wurdz! Da mitt Janett!
                        Last edited by Von Hilde; 10-09-2016, 06:20 AM. Reason: Spelt a bad word correctly, and had to change it
                          What Bad word? Ill have to check
                            Here are some out of addition #5:
ID:	116711Click image for larger version
ID:	116712Click image for larger version
ID:	116713Click image for larger version
ID:	116714Click image for larger version
ID:	116715Click image for larger version
                              The 'attached files' are what you are considering as smaller files? These are the initial files you uploaded. From them, you post them wherever you want them in your text.
                                Actually they show up at the bottom of the posted page and I dont want them there but they wont go away.
                                  Kazzer commented
                                  Editing a comment
                                  If you look at the window where the mini pics are, at the bottom of the page, you'll see there is an X at top right. Click on that when you are finished and they'll go away
