Cricut!
    Cricut!
    I just came across this neat little machine that cuts patterns in a number of materials.
    I'm not quite sure how it gets from a drawing or photo to be able to cut out the shapes, but if it could be used to cut vinyl or aluminum foil, I can see where this would make the ideal stencil for doing brass frets.
    Has anyone seen this little gadget before?
    • 13908
    That is so slick! I'm sure it will cut adhesive backed aluminum foil and .005" thick plastic sheet. Stencils, parts, markings, PE masks, etc. ....
      She who must be obeyed shall have no rest before I got one of these in my basement.
        Maybe the era of scribing detail onto GRP hulls is over. If only someone could could up with the templates?
        • type7
          • 196
          Looks very easy and affordable compared to maybe, the Roland cutters. Can see it for templates or to stick on details like you said.
          • type7
            • 196
            Here is some info on other cutters: http://maxcnash.com/best-die-cutting-machine/
            You can get a laser cutter for a bit more money but it has some advantages.
