Photo test - again
    Photo test - again
    [ATTACH=CONFIG]n115409[/ATTACH]
    Aaaaaaaaaaaaaaaaaaa
    [ATTACH=CONFIG]n115411[/ATTACH]
    XXXXXXXXX
    SSSSSSSSSS
    [ATTACH=CONFIG]n115421[/ATTACH]
      Well! Would you believe that! I got one photo to come out large, but I can't seem to duplicate the process. What a pain in the ass this program is.
      [ATTACH]n1684[/ATTACH]
        Aha! Bingo! Maybe!!
ID:	115444Click image for larger version
ID:	115445Click image for larger version
          aaaaaaaaaaaaaaaaa
ID:	115449Click image for larger version
            qqqqqqqqqqqqqqqqqq
              Well! I think we've all been down this road before, but I have discovered that the Vbulletin website says they need some sort of Flash add on which they can't afford. Beats me!
              However, I'm going with this in future.
              1. Put all my Sub-driver pics in a folder named - sub-driver forum. Then make sub-folders for each topic and dump my pics into them.
              2. Open the Post a topic on the forum
              Look for the A in top right corner = ADVANCED EDITOR and then look for the IMAGE icon and upload the photo into the page. Add some text and then load another photo. It's one at a time, but I think this allows one to add some narrative, making the read more interesting.
              But you probably knew this already!
                • 13998
                Keep at it, Mike. You'll work this thing out
                  I just went to Albion's M1 post and saw a load of thumbnail photos at the bottom of his latest post - #1. When I opened the post as an editor, I simply clicked on the first photo thumbnail (full size) and somehow opened the photo at the top of the post. I continued down, opening each one and as you can see, they all came up in full size.
                  I'm going to try to repeat this. Obviously, the photo is stored in full size, it's just a case of figuring out why they won't do it without a lot of ***** about.
                    I am using the A for Advanced Editor mode. Top right of the Post Reply page.
                    Click on the IMAGE icon next to the CHAIN LINK icon. Click image for larger version
Name:	Icons for forum.png
                    Next - choose UPLOAD Click image for larger version
Name:	Icons for forum2.png
                    Next CHOOSE FILE _you can only choose one at a time. Click image for larger version
Name:	Icons for forum3.png
                    Next - choose SEND TO SERVER - this should post the photo to the place in your post where your cursor was.
                    It beats me why these 'attached files' are below the post.
                      Lets try something else. Click image for larger version
Name:	new tug boat.jpg
Name:	tug boat detail 2.jpg
Name:	tug boat detail 1.jpg
Name:	tug boat detail 3.jpg
Name:	tug boat above.jpg
                      Well! That was weird! I uploaded the 5 photos as 'attachments' and they showed up as small icons. Then I clicked on 'FULLSIZE' and they appeared in the post as - yippee! - FULL SIZED.
                        Note in this last post that there is only one file left as an 'attached file' . I added that one after I had posted the post. All the other photos are in the post as large pictures, and no longer in the 'attached file' list. However, the addition as an edit is now in the list.
                          Lets retry this and get ALL the photos posted in the initial photo upload.
                          DO NOT use the IMAGE icon - use the ATTACHMENT icon and click on UPLOAD ATTACHMENTS. You can highlight ALL the photos you need at once and they will load.
                          Once they load, you'll see them all listed below the post as small icons.
                          Click against each icon where is says FULL SIZE.
                          Now I'll do that and the photos should all be listed in the post at full size. I should be able to add text against each photo Click image for larger version
                          Two or three of them refused to go to full size, but I think this seems to be a much better setup. I'm going to call it a success!
                          I'm not sure why they all didn't come out large, so I'l try one more time
                            OK! Once more! Click image for larger version
                            one Click image for larger version
                            two Click image for larger version
                            three Click image for larger version
                            four Click image for larger version
                            five Click image for larger version
                            six Click image for larger version
                            seven Click image for larger version
                            eight Click image for larger version
                            nine
                            ALL LOADED PERFECTLY!!!!!!!!!!
                            And notice I added text as I added the photos!
                            SO-o-o-o-o! The trick is to get all your photos into one place/folder etc, where you can highlight the list of photos and then upload them as attachments.
                            Once this is done, you can choose each one from - small, medium, large of full size by clicking on those names in the attachment list below the post.
                              Note the one file in the 'attached files' - I think I just missed it in the initial posting to the post.
