Grab Bag Assortment Tinkerer's Kit
    We're clearing out some inventory, so have put together a Grab Bag of Goodies for you.
    Here's what in the bag! 1 each large and small RCABS Bladder
    1 larger water pump
    1 small gear pump
    9 assorted connectors
    1 12 point switch
    3 on off switches
    10 assorted push rod/shaft seals
    1 solenoid valve
    2 yoke leads
    2 lead extension
    4 Dumas done bone kits
    2 linear servos
    $30 the lot plus shipping (About $5)
    The gear pump alone is worth the money
    To order https://sub-driver.com/grab-bag-assortment.html
    Has anyone sorted out these damned photos on this forum? Because, suddenly I can't get a photo to load in a large format! Why is this so difficult?
      • 3754
      Talk to your son. He moved to this version of vBulletin. We have been bemoaning the picture loading feature since the upgrade happened. Many are starting to use a third party photo storage (like photobucket or imageshack or such) only putting links in postings.
        • 13980
        Don't know 'why' Mike, but as Tom's pointed out some of us have had to go to the very cumbersome solution of using off-board, off-computer picture hosting sites if we want big format pictures to appear here.
        • Pawly
          • Jun 2013
          • 59
          If you are clearing out, why does it take 4 to 6 weeks to put it together??? Must be a big lay down area you have?😜 Or maybe it is something in the water........😏
            I have no ducking idea! Just ignore it. Magento sucks these days.
            • Pawly
              • Jun 2013
              • 59
              Bit hard toning ore when they say it will take 4 to 6 weeks to do a fittings kit and they cannot tell me when i will get it after 3 months. Is spose it depends if they get the gear from the same bloke. 🙄
              • Pawly
                • Jun 2013
                • 59
                Bit hard to ignore, not toning ore.... Damn auto spelling.😊
                  • 3754
                  Ordered my grab bag on the 7th, it arrived today! Thank you Mike!
                    I'm throwing HWSNBN under the bus here! When you feel the bump - back up - twice!
                    • small sub guy
                      • Dec 2009
                      • 45
                      Ordered my grab bag... it arrived today
                      Thanx Mike
