Grab Bag Assortment Tinkerer's Kit
    We're clearing out some inventory, so have put together a Grab Bag of Goodies for you.
    Here's what in the bag! 1 each large and small RCABS Bladder
    1 larger water pump
    1 small gear pump
    9 assorted connectors
    1 12 point switch
    3 on off switches
    10 assorted push rod/shaft seals
    1 solenoid valve
    2 yoke leads
    2 lead extension
    4 Dumas done bone kits
    2 linear servos
    $30 the lot plus shipping (About $5)
    The gear pump alone is worth the money
    To order https://sub-driver.com/grab-bag-assortment.html
    Has anyone sorted out these damned photos on this forum? Because, suddenly I can't get a photo to load in a large format! Why is this so difficult?
      Talk to your son. He moved to this version of vBulletin. We have been bemoaning the picture loading feature since the upgrade happened. Many are starting to use a third party photo storage (like photobucket or imageshack or such) only putting links in postings.
        Don't know 'why' Mike, but as Tom's pointed out some of us have had to go to the very cumbersome solution of using off-board, off-computer picture hosting sites if we want big format pictures to appear here.
        • Pawly
          • Jun 2013
          • 59
          If you are clearing out, why does it take 4 to 6 weeks to put it together??? Must be a big lay down area you have?😜 Or maybe it is something in the water........😏
            I have no ducking idea! Just ignore it. Magento sucks these days.
            • Pawly
              • Jun 2013
              • 59
              Bit hard toning ore when they say it will take 4 to 6 weeks to do a fittings kit and they cannot tell me when i will get it after 3 months. Is spose it depends if they get the gear from the same bloke. 🙄
              • Pawly
                • Jun 2013
                • 59
                Bit hard to ignore, not toning ore.... Damn auto spelling.😊
                  Ordered my grab bag on the 7th, it arrived today! Thank you Mike!
                    I'm throwing HWSNBN under the bus here! When you feel the bump - back up - twice!
                    • small sub guy
                      • Dec 2009
                      • 45
                      Ordered my grab bag... it arrived today
                      Thanx Mike
