Good defaults with the exception of the LPB.
You don't want a boat sitting on the bottom for hours with the LPB motor running -- you'll kill the Lithium-polymer battery. Also, if one of those cast rubber diaphragm pump elements tears, you'll flood the SD.
On loss of signal, the LPB pump-motor remains off.
Loss of signal - what should happen by default
Friends,
I have just modified (for about the 4th time) my Small World Models Blueback. This time I added a KMC ADF1 and a SNORT system, Pix will follow of the SNORT install. I am using a SOMBRA SL-8 receiver which has programmable fail safes. This is how I programmed them. I am looking for feedback to see if I chose the right fail safes.
On loss of XMTR signal:
1) Motor stops,
2) Ballast system is set to blow ballast, and
3) SNORT is turned on.
Does this look OK? Is there more I could have done?
Thanks for your time,
Dan
