AD2/FRSKY/X- rudder mechanism Mix
  • biggsgolf
    • Jan 2020
    • 1036
    When implementing AD2 with XRudder Mix, which should I program first the AD2 or the XRudder Mix?
    You cant use transmitter mixing for x-tails when used with a leveller. You have to use an onboard mixer.
    • biggsgolf
      • Jan 2020
      • 1036
      Awww, I was thinking that to be the case! So use X-Tail MIXer, and not the TX to do the mix?
        • 14013
        Yup. The typical V/X-tail mixer is an on-board device that indirectly inputs from the receivers ch-1 and ch-2 ports, and outputs to the two servos that drive the stern planes/rudders. The angle keeper plugs in between the receivers ch-2 and outputs to the mixer input.
        • Fishb0y
          • Jul 2023
          • 168
          I am using a stabilized RX (SR6) from FrSky to both mix the X-tail and add stabilization. I'm still ironing out the process, but I'm happy with what I have so far.
          • biggsgolf
            • Jan 2020
            • 1036
            Thankyou sir!
            • biggsgolf
              • Jan 2020
              • 1036
              Sounds good!
                A receiver with built in leveller will work yes, as will a leveller with a built in x-tail mixer.
