SD question
  • Tugfan
    • Nov 2010
    • 178
    SD question
    Will the linkage and such be included in the kit?
    • 13719
    Too criptic, ******! Amplify!
    • Tugfan
      • Nov 2010
      • 178
      Huh? Will the rudder and dive plane linkage be included in the SD package? Also I'm rather confused on the sail construction. I also see nothing about how the sail stays put on the hull. Maybe magnets?
        • 3681
        Tugfan, i will take a stab here, are you referring to the Moebius SKIPJACK fittings kit or the wtc? I think David needs to know which system you are talking about. The sub drivers on previous kits were just the wtc. Fittings kits worked on other areas of the kit to make it r/c. http://www.sub-driver.com/fittings-k...ngs-kit-1.html see if this is what you are asking about.
        • Tugfan
          • Nov 2010
          • 178
          The fittings don't come with linkage. Dave's speaking in tongues again.
            • 3681
            What linkages are you talking about????
            • Tugfan
              • Nov 2010
              • 178
              The rudder/dive plane linkage. Very Angry
                • 13719
                Ahhh .... I bask in the heat of your angst. Is Gooooooodddddd!
                No! Damit, make 'em yourself!
                I'm not done with the instructions -- wait along with everyone else to find out.
                • Tugfan
                  • Nov 2010
                  • 178
                  Well ******, I'm in a hurry. So there. Also, the sail instructions are confusing. The rest is cake.
                    • 13719
                    More dope on the sail linkage forthcoming, damit!
                      • 13719
ID:	74488Click image for larger version
ID:	74489Click image for larger version
ID:	74490Click image for larger version
ID:	74491Click image for larger version
ID:	74492Click image for larger version
ID:	74493Click image for larger version
ID:	74494Click image for larger version
ID:	74495Click image for larger version
