SD question
More dope on the sail linkage forthcoming, damit!Leave a comment:
Well ******, I'm in a hurry. So there. Also, the sail instructions are confusing. The rest is cake.Leave a comment:
The fittings don't come with linkage. Dave's speaking in tongues again.Leave a comment:
Tugfan, i will take a stab here, are you referring to the Moebius SKIPJACK fittings kit or the wtc? I think David needs to know which system you are talking about. The sub drivers on previous kits were just the wtc. Fittings kits worked on other areas of the kit to make it r/c. http://www.sub-driver.com/fittings-k...ngs-kit-1.html see if this is what you are asking about.Leave a comment:
Huh? Will the rudder and dive plane linkage be included in the SD package? Also I'm rather confused on the sail construction. I also see nothing about how the sail stays put on the hull. Maybe magnets?Leave a comment:
SD question
Will the linkage and such be included in the kit?Tags: None
