How to Solder
    • 3636
    How to Solder
    Hi David,
    Can you make a cabal report here on how to solder noise suppression capacitors and ESC wires to the motor leads? Actually you mentioned it in one of your articles in personal site http://vabiz.com/d&e/articles.html about the 2 inch Sub Driver. You even made a unique soldering jig. Unfortunately the photos in that site are mysteriously missing. Hope you can make a new one here.
    • 13879
    You know, that's a damned fine idea (oh! ... before I forget: Finish your Damned KILO!!).
    What with a clients recent broken blow-valve and the angst suffered by others over putting their wires together, coupled with the need to solder the MPC's to the LPB motors -- all good reasons to get you guys into the black-art of soldering.
    I'll work it up as a Cabal Report and have mike post it in the Gazette, and I'll reduce it to a piece for this thread.
    I'm doing a show tomorrow so I'm busy pre-mission checking boats and will be busy post-mission checking those same boats tomorrow night. But, I'll work on the article Sunday.
    Good call. Here's a tease for you till then:
ID:	68043Click image for larger version
ID:	68044Click image for larger version
ID:	68045Click image for larger version
ID:	68046Click image for larger version
ID:	68047Click image for larger version
ID:	68048Click image for larger version
ID:	68049Click image for larger version
ID:	68050Click image for larger version
ID:	68051Click image for larger version
ID:	68052Click image for larger version
ID:	68053Click image for larger version
ID:	68054Click image for larger version
      • 3636
      Still got that jig you made from a clothespin?
        • 651
        Lesson "-1", buy a decent soldering iron
          • 2574
          Yiou don't have to spend a fortune. I got a really nice temperature controlled 50 watt iron for £10 from Maplin. Works great.
            • 13879
            UNDER CONSTRUCTION ........
            Solder materials
            soldering tools
            soldering fixtures
ID:	68077Click image for larger version
ID:	68080Click image for larger version
ID:	68086Click image for larger version
ID:	68092Click image for larger version
ID:	68093Click image for larger version
ID:	68096Click image for larger version
ID:	68108Click image for larger version
ID:	68099Click image for larger version
ID:	68101Click image for larger version
            soldering techniques
ID:	68079Click image for larger version
ID:	68082Click image for larger version
ID:	68084Click image for larger version
ID:	68085Click image for larger version
ID:	68087Click image for larger version
ID:	68090Click image for larger version
ID:	68094Click image for larger version
ID:	68095Click image for larger version
ID:	68098Click image for larger version
ID:	68100Click image for larger version
ID:	68102Click image for larger version
              • 3722
              I like the Ellie has Ninja soldering skills pose.
              • Anuci
                Banned
                • 165
                POI, There are many soldering tutorials available on Youtube.
                Try this: ...http://www.youtube.com/results?searc....0.jh5knulxCj4
