Revell Type VII Sub Driver Flap Valve problem
  • ir3aus
    • Mar 2010
    • 56
    Davie,
    The flap valve on the ballast tank will not seal. I have tried smoothing out the seating surface; I have tried recentering the flap over the hole; I have tried various pressures on the lever used to seal the air escape hole and nothing helps. I used RTV around the outer surface where the flapper valve housing is attached to tube. There was air escaping through a gap where the rubber flap is attached to the housing.
    Need help.
    Iran
    There is a fine line between hobbies and mental illness!
    • 14013
    Originally posted by ir3aus
    Davie,
    Need help.
    Iran
    E-mail me your mailing address and I'll send you two vent valve assemblies right away. dmeriman@aol.com
      and this is why gentleman you buy with confidence from David and Mike. Remember the sticker price with David and Mike means parts back up should something go awry. Excellent customer service.
