Finishing a Propeller
  • 639mpa
    • 68
    Hi David,
    In your Detailing the OHIO DVD you show how to finish and paint the prop. Radio Shack no longer carries the circuit board etch which is used to etch the metal prior to priming. Can you give a new source for small amounts of this etch?
    Thanks,
  • ManOwaR
    • Jul 2009
    • 217
    Hi Bob,
    I've heard that vinegar works if you leave the part soak over-night. Either that or you can always use the old stand by in Coca Cola!
      • 13968
      Joel's right on the money, vinegar will do the trick. Bring it nearly to a boil and soak and agitate in that -- so it won't take all night.
        • 2635
        You could also use an etch primer.
          Dave, I just bought Caswells nickel plating kit for my props. Should I follow the instructions in the kit as far as prep or should I pickle them with vinegar first or the Ferric Chloride if I can find some?
            • 13968
            No, give them a nice bright finish with #600 sandpaper, Mark.
              Gotcha! Sir
                Follow the instructions Good grief!
                  • 13968
                  Lol.......
                  Rtfi!
                    As Piglet would say: "OH DEAR, OH DDDDE.....DDDE....DEAR..DEAR!"
                    • Tom Spettel
                      • Dec 2009
                      • 53
                      If you still want the circut board etch MG chemicals carreis the stuff..but Mikes plating kits are cool and if im correct Mike said to plate the props with the crome for added strenght then plate with bronz right?
