Availability of 1/96 Skipjack
  • roedj
    • 564
    Sirs,
    I see from the Caswell site that the 1/96 Skipjack is "out of stock". Are there any plans to build more of these kits?
    Dan
    • 14013
    Hell yes! I'm currently re-tooling the GRP hull and GRP parts as well -- this will make for a cheaper to produce, easier to assembly kit. The SKIPJACK is the best running r/c submarine I've ever had the pleasure to drive. It would be the height of stupidity not to continue the availability of this product.
    • roedj
      • 564
      I look forward to the day I can build - no wait I meant assemble, I meant assemble - one.
      Dan
        • 14013
        I love a man who employs the correct terms. Well ... I mean, I like ...
        Oh! ...
        ... Never mind!
        • daveg
          • Jul 2009
          • 22
          Dave I bought your 3" sub driver some years ago and I assume it will work well with the new retooled Skipjack?
          Dave G
            • 14013
            Yes it will. The WTC-3 was specifically designed for the 1/96 SKIPJACK.
            • Outrider
              • 304
              Are you going to offer saddles for the new two inch drivers as well (like you did in the D&E Type-212)? I suspect either driver would give sufficient performance...
