Revell Skipjack receiver question
  • Oldlugger
    • May 2009
    • 3
    Hello all,
    I am thinking of purchasing the Revell Skipjack sub with most of the associated RC conversion components from Caswell Plating. As I am based in Europe our frequency rates are different to those in the US as you know; in the UK it is usually either 40Mhz or 27Mhz. My question is does anyone know of a suitable mini receiver for the Revell sub that I could use here and where I could get it? Would I need to substitute any other RC component in the Caswell RC kit in this respect? I am a novice so excuse my lack of knowledge.
    Cheers
    Simon :wink:
    • 2125
    The Schulze or Jeti range will do you nicely-
    ie.
    Delta 5
    • Oldlugger
      • May 2009
      • 3
      Cheers for that.
        • 2125
        Where are you based in the UK?
          • 2848
          We have in stock some 6 channel WFLY 40mhz radios with very small receivers that will fit the Skipjack Sub-driver.
          They are 1.4" long .85" wide .6" thick with ch 69 crystals
          Don't have a price yet, but I suspect they'll be about $75-80
          • Oldlugger
            • May 2009
            • 3
            Many thanks for the info kazzer. Does anyone know if the Revell sub kit from Caswell, its fittings kit and the wtc are still available for sale?
            Cheers
            Simon
              • 2848
              Cheers
              Simon
              see
