Revell Skipjack receiver question
  • Oldlugger
    • May 2009
    • 3
    Hello all,
    I am thinking of purchasing the Revell Skipjack sub with most of the associated RC conversion components from Caswell Plating. As I am based in Europe our frequency rates are different to those in the US as you know; in the UK it is usually either 40Mhz or 27Mhz. My question is does anyone know of a suitable mini receiver for the Revell sub that I could use here and where I could get it? Would I need to substitute any other RC component in the Caswell RC kit in this respect? I am a novice so excuse my lack of knowledge.
    Cheers
    Simon :wink:
    • 2641
    The Schulze or Jeti range will do you nicely-
    ie.
    http://www.rctechnics.eu/jeti-40mhz-...ml?language=en
    Delta 5
    http://www.schulze-elektronik-gmbh.com/prs41_e.htm
    • Oldlugger
      • May 2009
      • 3
      Cheers for that.
        • 2641
        Where are you based in the UK?
          We have in stock some 6 channel WFLY 40mhz radios with very small receivers that will fit the Skipjack Sub-driver.
          They are 1.4" long .85" wide .6" thick with ch 69 crystals
          Don't have a price yet, but I suspect they'll be about $75-80
          • Oldlugger
            • May 2009
            • 3
            Many thanks for the info kazzer. Does anyone know if the Revell sub kit from Caswell, its fittings kit and the wtc are still available for sale?
            Cheers
            Simon
              Cheers
              Simon
              see
