Moebius RC Seaview
  • Stan Ritter
    • 10
    Moebius RC Seaview
    Hello:
    Was wondering if anyone out there has the linkage measurements and all bend angles for all the linkages for seaview? The linkage for bow planes/rear planes look like a nightmare. Need the measurement for the drive shaft also.
    I have the seaview how to build video, but does show to much on linkages as far as what I asked here.
    Thanks for any help
    Stan
    • 13749
    Originally posted by Stan Ritter
    Hello:
    Thanks for any help
    Stan
    Stan,
    Sorry about the delay. Below I've laid out how the linkages are arranged within the SEAVIEW:
    (just took the measurements off one of the two bow plane-stern plane pushrods)
      • 13749
      The pushrod measurements:
      • SteveJ
        • 56
        Dave
        Thats a neat coupling your using to tie the bow and stern planes. I was going to solder small collars together to make one.
        Steve
          • 13749
          Originally posted by SteveJ
          Dave
          Steve
          Yeah, the pushrod coupler I made makes individual adjustment of the four (2-stern plane, 2-bow plane) control surfaces easy and sure. But, you can get away with a 3/16"i.d. wheel-collar to gang the three wires together.
          • Rick Teskey
            • Jan 2009
            • 265
            Hi Dave
            The rust evedent on the klickons , is that a result of chlorinated water?
            Does it affect the magnets?
            Rick
              • 13749
              Hi Dave
              Rick
              That's good old Iron oxide, Rick. Though the magnets are Chrome plated (I assume its Chrome), if they get nicked the Iron quickly oxidizes and you get rust. No big deal ... call it, 'weathering'.
              • dave_mcwhite@cox.net
                • Sep 2009
                • 22
                Please sell us your 3 Push Rod Connector fitting?
                Ever thought of adding the pushrod coupler you made for the Seaview to the SEAVIEW's Fittings Kit (or sold seperately)? As you stated "dividual adjustment of the four (2-stern plane, 2-bow plane) control surfaces" makes it easy to account for slippage over time of the three different pushrods.
                Sincerely,
                Dave McWhite
                  • 13749
                  Sincerely,
                  Dave McWhite
                  Yes, but dropped the idea as it increased the coast of the fittings kit. So I let the end-user figure that one out. A 3/16" wheel-collar will get the job done.
                  • Stan Ritter
                    • 10
                    Slip marks
                    I'm going to try to paint or mark (with permanent ink, good old sharpie) slip marks on the linkages next to the linkage collar. This way you should be able to tell if a linkage or linkages have slip from collar. I will let everyone know later if this holds true.
                    Stan
                    • Stan Ritter
                      • 10
                      3-way bow/stern coupler
                      Hi Dave:
                      Can I purchase that neat 3-way bow/stern linkage coupler yet?
                      The collar coupler works, but what a pain. I need and desire the indivial bow plane ajustment it affords. Seems like you adjust one bow plane and the the other side falls out adjustement. Cannot get that neautral setting of the bow planes with the collar it seems.
                      Please, please I hope I can purchase the 3-way now or real soon.
                      Stan
                        • 13749
                        Hi Dave:
                        Stan
                        No, ******! Make your own.
                          I think his pink underwear must be too tight! He's grumpy! (He has to wear them for swearing on this forum!)
