Revell Skipjack and salt water exposure
  • CEberhardt
    • Aug 2010
    • 2
    My research group at UVA is looking for a RC sub for use in a salt water pool. The Revell Skipjack and conversion kits from Caswell look like a good option for our work. I was hoping someone with experience with this model can provide details about the speed and turning radius or any potential issues with salt exposure. I have zero experience with running or building RC models so any advice or other recommendations would be appreciated. I assume I need to purchase:
    Revell Skipjack Model, Sub-Driver & Fittings Kit
    The Revel Skipjack Electronics Kit:
    BT50 2 x Micro Servos @ $8 each
    ESCMN 1 x Nano Speed Controller $29.00
    AK1 1 x ADF Pitch Controller and Failsafe $79.00
    SL675 1 x Nano Radio Receiver 75mhz with crystal $38.00
    KSE002-LPG 1 x LiPo Guard Battery Saver $49.95
    V800 1 x 800 Mah LiPo Battery $18.00
    VC1 1 x Battery Charger For 7.2V Batteries $23.00
    Anything I may be overlooking? Thanks
    Salt water attenuates or limits the transmission of radio waves. You will have a hard time controlling your sub. Unless you'll be running your model at periscope depth all the time with the receiver antennae sticking out of the water ( inside scale mast).
    • CEberhardt
      • Aug 2010
      • 2
      Would it be possible to add a wire antenna connected to a small float (eg fishing float) that the sub tows.
