Completed and in the clients hands. runs very well, good speed, reasonable turning radius (once under water), and is hands-off once the stern plane trim is dialed in for speed.
Only construction point I would make, without further inquiry from you, is to maintain the OTW flanges on the two hull halves -- I removed them and the parts warped terribly. Took forever to fix with internal frames. Dumb move on my part. Leave the flanges on the hull halves!!!!!!
Nice kit, runs well, looks like hell.
Vanguard Build
Vanguard Build
I've read the Cabal report on the OTW Vanguard improvements.
Would I be correct in thinking that at some stage a full build was done, if so, is it posted anywhere?
I'm well on with mine now complete with a set of improved control surfaces etc but a little guidance here & there wouldn't go amiss!!Tags: None
