Revell type IX rc conversion
  • Unterwasser
    • Mar 2014
    • 10
    Hello to everybody! I'm from Italy and after a schnellboot and a type VII, i'm starting with a new project: a conversion of Revell type IX with static dive.
    I was thinking about a snort ballast system and two 400 motors. What do you think guys?
  • crazygary
    • Sep 2012
    • 610
    Welcome to "the pen", Unterwasser!!
    I'm sure all of your questions will be answered is short order on this forum.
    Plenty of quite prolific modelers here who will share their knowledge with anybody!!
    Glad to have you aboard!
    CG
    • Unterwasser
      • Mar 2014
      • 10
      Thankyou Crazygary! It's a pleasure for me and i'm waiting for all the ideas everybody will give me.
      Asap i'll post some photos of my ship, actually i'm working at rudder shafts, hull and, maybe next week, the wtc.
        • 13868
ID:	90948Click image for larger version
ID:	90949Click image for larger version
        • Unterwasser
          • Mar 2014
          • 10
          Very interesting photos, thay gave me some ideas...
          I was in trouble for the the motors sealing shafts: simmerring? Grease?
            • 13868
            U-cup seals.
              • 3721
              Maybe you did this already, but David has a build he started here is were he begins talking about his WTC: http://forum.sub-driver.com/showthre...ht=revell+type
              Maybe this will help with motor size.
              • Unterwasser
                • Mar 2014
                • 10
                I read all the thread about Dave's type IX before start my project! I've got a 50 mm dia (46 int.) plexi tube and i was thinking to use it for my wtc. With that measures i must choose if use 1 type 400 motor with reduction or 2 smallest (i don't know the size) that i've bought to use on my Italeri MAS. Altenatively i can choose for a 60 mm dia plexi tube (54 internal). In this case i can use two type 400. Battery is a nimh 7.2 V.
                What are u-cup seals?
                • crazygary
                  • Sep 2012
                  • 610
                  Here's a photo for you, Unterwasser!!
Name:	u-cup seals.jpg
                  They're generally installed with the face that you're looking at
                  pointing towards the prop! Water can't enter against the seal.
                  CG
                  • crazygary
                    • Sep 2012
                    • 610
                    A better photo showing the cross-section!!
                    CG
                    • Unterwasser
                      • Mar 2014
                      • 10
                      I know them! In Italy sometes they're called "corteco" aka "simmerring" (in Germany). I used one to seal the shaft in my LA class (still work in progress...).
                      Yesterday i worked on the hull, still thinking about wtc ad motors...
                      • Unterwasser
                        • Mar 2014
                        • 10
                        My LA class...
                        • Unterwasser
                          • Mar 2014
                          • 10
                          After several days i'm still at work. Made aluminium bushes for rudders and prop shafts with 2.3 mm inox steel.
                          This week i'm going to start with wtc end caps. I found those motors on rc-sub-workshop
                          http://www.rc-sub-workshop.com/Details.aspx?id=283
                          Do you guys think are ok?
