Skipjack
Still Dry. Small leak in the roof but alls well. Glad storm stayed to the East -
Yea David still dry. Had leak in roof however so one wall not so dry. Glad the storm stayed to the east.Leave a comment:
You still dry, Steve? We're still breathing air ... thank goodness!
MLeave a comment:
Good catch on the old seam-filling article, Bart. Thanks.
MLeave a comment:
Have made some progress..Slowed a little due to the weather and a roof leak. As the one photo shows with the hull together I still have a little gap. Any ideas on how to correct this are very welcome. I could not be doing this without all the great threads people have posted on the building of their skipjacks. I thank you again
If you need to ensure some float and don't have access to feeler gauges, then a cigarette paper works well or failing that a piece of newspaper. Push prop hub up against bearing, place paper between coupler and the other bearing, hold the assembly snug, but not so tight that paper can't be pulled out. Tighten grub screw, remove paper. Instant float., the poor man method.Leave a comment:
The e-mail did not get through. Tell you what, I'll post the N.C. 1/96 model run thread here so you and anyone nearby can consider making the event early next month: http://www.wmunderway.8m.com/cgi/yab...num=1422916002
It was a pleasure hooking up with you, Steve.
My e-mail address is, dmeriman@aol.com
DavidLeave a comment:
David I sent you my e-mail after I got home from your shop on Saturday, Was looking for the info on the event in North Carolina- tried to send a visitor message but it will not let me. Thanks for the visit and all the help you provided.Leave a comment:
I fixed the stern planes. First time ever using a Tap. Thank you David!!!Leave a comment:
At the universal coupler end (forward) shorten the shaft a bit and extend the shaft set-screw flat as well. With both thrust washers in place, there should be a .003-.005" gap.
It appears to me there too much of a gap. I think I should extend the flat to make it more snug
