Congruent with my Permit class build, I have commenced work on an Albacore.
The hull is the plastic vac formed version, although I have ordered from David new dive planes / rudders / sail / appendages and other equipment which will be used in place of the vac formed ones.
The hull I purchased a while back from Mikes Sub Works as a "hull only" kit. Most would know that the vac formed Albacore was a standard product line from Skip Assay, and many RC submariners either cut their teeth on this boat as an entry to the hobby or at some stage gravitated to this well thought out kit.
Shortly after I entered the hobby I toyed with the idea of buying this kit, but never got around to getting one. The subject of the Albacore to me is a must have boat. As a nerd for history and technology this boat was in my view pretty much the ultimate test bed for taking submarines into the modern age.
Ok here you can see the vac formed pieces of the hull kit.
Next note the value of the Subdrivers Website and the genius of David Merriman (one of the finest engineers the hobby has). You'll see I have made a shop copy of key photos of how David put his latest Albacore together - combining the Vac formed hull and his custom made upgrade parts. I won't be using the exact same methodology as David, but there are some techniques and tips that I'd be silly not to adhere too.
