OTW NACKEN BUILD THREAD HMS Neptun
  • ffr2608
    • Oct 2009
    • 347
    #46
    With a boat this size, trimming is really easy. I think I took the shot before everything settled. I love having the ability to go full negative with the tube. I use the ATV in the radio to make adjustments. One click on the ATV button, the piston moves about 1/16". My range is almost decks awash to sitting on the bottom. At surface trim, I can adjust about 1/2" up or down the waterline. Pretty slick.
    D
      Nice! I especially like the detail on the top of the sail. Its also really handy to have that much control over your diving, even with no forward motion.
      • ffr2608
        • Oct 2009
        • 347
        #48
        Base black paint is fully cured and dull coated. Got the vinyl masks made for the torpedo door rings and demarcation lines. (no numbers) Tomorrow, I will start the hull color plating with 4 or 5 different shades of black like the conning tower. This is also a great way to touch up flaws or scratches on the main color. After that cures, I will strike the waterline and add some light marine growth. Plan is to run her at Cerritos Regional park this Sunday.
        • ffr2608
          • Oct 2009
          • 347
          #49
          S T E P A W A Y F R O M T H E A I R B R U S H ! !
          Got the waterline scum on the hull and finished up the white and orange details. The green is very subtle but I wanted to see If I could actually stop when I should with the weathering.
          Things left to do:
          dry brushing flood vents, waterline touch up
          zincs around propeller
          install linkages and prop
            • 13982
            #50
            Oh, man!
            It's official: I hate you!
            Less is more.
            • SSBN659
              • 418
              #51
              Nice looking model. I particularly like your torpedo tube ring masks but how did you secure the center circle of the masks?
              "Will" Rogers
              SSBN659
              • ffr2608
                • Oct 2009
                • 347
                #52
                Thanks, That is held in place with a transfer sheet. Like all vinyl decals.
                • ffr2608
                  • Oct 2009
                  • 347
                  #53
                  FINISHED!
                  Got the zincs on, final waterline treatment and the flat clear sprayed out. Sea trials are tomorrow at Cerritos Regional park.
                  • Peter W
                    • May 2011
                    • 511
                    #54
                    Darrin that is a stunning looking sub, I love the finish looks perfect.
                    Peter
                    • ffr2608
                      • Oct 2009
                      • 347
                      #55
                      Ran the boat 3 times today. After some adjustments with Will, I am at about 95% trimmed. Did a few adjustments at home and couldn't be happier. It was really bright and hot today so the iphone shots are a bit hot. May get some better shots later today. Boat ran very well for the first time out. Second shot almost looks real.
                        • 13982
                        #56
                        Excellent!
                        What's actuating your scope?
                          Wow! That boat is a HUNK! Congratulations.
                          • ffr2608
                            • Oct 2009
                            • 347
                            #58
                            Dave, slide in by hand. K.I.S.S. My club has a big issue with runaway boats, bad drivers and several Tupperware go fasts. The scopes have a 1/2 razor cut in them so they break off when there is a collision. It's going to happen soon.
                              • 13982
                              #59
                              Scope with a crumple-zone. Hey! .... you some kind of car engineer or something??
                              Yupe, better to have that scope fail rather than the sail
                              • ffr2608
                                • Oct 2009
                                • 347
                                #60
                                Yep, I cast up the tips to slide into standard alum. tubing. I have 3 backups for now. (all different lengths)
                                D
